Jack handle placement in the Gen 1 two door #1065318 10/28/13 05:21 PM
Grasscat Offline OP
Where is the jack handle stored in the Gen 1 two door?
Michael j
TreadLightly! Trainer
Re: Jack handle placement in the Gen 1 two door [Re: Grasscat] #1065319 10/28/13 06:19 PM
iirc, there are 2 clips on the carpet in the forward section that's under the rear seat. In my red one they were broken off and I bought 2 new ones at the dealer.
Re: Jack handle placement in the Gen 1 two door [Re: off-roader] #1065320 10/28/13 11:14 PM
Grasscat Offline OP
I thought that also, but there is no clips and it shows no sign of there being any hole where the clips may have been.
I posted it was a Gen 1, but it's a 89 two door Raider. Maybe there is some difference between them, but I would not think so.
Michael j
Re: Jack handle placement in the Gen 1 two door [Re: Grasscat] #1065321 10/28/13 11:24 PM
JAVYPRO Offline
Yes, that is a GEN I, it goes right there. Undo the buttons and pull the carpet and you will see the holes. I find it to be a bad spot because your passengers, if any, will step right on the clips or the handle and they will brake off.
Happened to me. My fix was, do you know those nylon bags for foldable chairs? Well I got one of those, very strong let me say, and in there I keep my tow strap, my hatchet, a miniature shovel and the jack handle.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Jack handle placement in the Gen 1 two door [Re: JAVYPRO] #1065322 10/29/13 02:30 AM
I may have the clips if you don't. I'll check tomorrow afternoon (-ish) and send them (in awhile, you guys know me) on if I have them. Alternately, I have some spring steel clips that are from a LUV truck (I think) that would work for you too.
Re: Jack handle placement in the Gen 1 two door [Re: rxinhed] #1065323 10/29/13 02:44 AM
Iirc on mine the clips were steel. The plastic pieces were just inserts used to mount the metal clips to.
Re: Jack handle placement in the Gen 1 two door [Re: off-roader] #1065324 10/29/13 03:13 AM
MarkG Offline
Somewhere I thought I saw a picture of a Gen I, 2 door with the jack handle (or something like a jack handle) attached at the very bottom of the rear bench seat.
Re: Jack handle placement in the Gen 1 two door [Re: MarkG] #1065325 10/29/13 05:04 AM
Oh yeah, and there too. The late 87 Raider I parted had that. All the others were in the rear footwell.
Re: Jack handle placement in the Gen 1 two door [Re: rxinhed] #1065326 10/29/13 05:31 AM
Grasscat Offline OP
Thanks for the offer Russell, but I have clips from the Montero's. Neither of the Raiders had them, go figure.
I will install the clips on the rear of the back seat.
Michael j
Re: Jack handle placement in the Gen 1 two door [Re: Grasscat] #1065327 10/30/13 12:27 AM
KO. <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6341 MB (Peak: 0.7427 MB) Data Comp: Off Server Time: 2026-06-07 04:49:56 UTC
