Page 1 of 3 1 2 3
Valve guide seals, which brand is best? #1065599 10/29/13 05:37 PM
motero Offline OP
Or should I only use OE?
Thanks
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Valve guide seals, which brand is best? [Re: motero] #1065600 10/29/13 05:55 PM
I bought a set off Rock Auto, but I haven't put them in yet, so I don't know if they're any good or not. They appear to be a pretty basic part, though, not much to them.
Re: Valve guide seals, which brand is best? [Re: JohnnyBfromPeoria] #1065601 10/29/13 10:28 PM
Djunk Offline
Good question, I've been trying to track the answer down for a while. I've found people on other sites for other vehicles say that Sealed Power and Felpro are good brands but I am still waiting to see if someone chimes in here. The price for oem seals seems awfully high.....we're talking about Valve Stem seals right?
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: Valve guide seals, which brand is best? [Re: Djunk] #1065602 10/29/13 11:37 PM
Re: Valve guide seals, which brand is best? [Re: fasteddy] #1065603 10/30/13 12:45 AM
Here are the ones I got, the VSS126 set at the bottom of the page:
Valve Stem Seals
On the package it says "Viton Valve Stem Seals." $19.70 for a set of 24.
Re: Valve guide seals, which brand is best? [Re: JohnnyBfromPeoria] #1065604 10/30/13 04:52 AM
mxmikie Offline
i rent the tool to replace them if you need it
Re: Valve guide seals, which brand is best? [Re: mxmikie] #1065605 10/30/13 05:10 AM
motero Offline OP
Thanks for the links good info. MXM What do you charge and do you have the air compressor adapter?
01 montero limited
Re: Valve guide seals, which brand is best? [Re: mxmikie] #1065606 10/30/13 05:13 AM
The viton seals are a good choice for any engine on which you are not renewing the guides ti restore the valve-guide clearance, otherwise I like teflon seals on new guides.
Re: Valve guide seals, which brand is best? [Re: fasteddy] #1065607 10/30/13 03:21 PM
Djunk Offline
Looks like the DNJ seals on rock auto are a good choice as long as they are Viton. It doesnt say anywhere on the website that they are but it looks like they are. Does DNJ list the specs anywhere on these seals? If they are they the same as the OEM exaust selas then i'll be getting them. Thanks for the link above to Engine Builder good info for sure.
On another note has anybody used the below spring compressor
with success? I found one person saying it works but have not been able to confirm it with him yet. Looks pretty slick and is only $74
http://www.euroexportinc.com/tools/valve-spring-tools/mitsubishi-4g63-valve-spring-compressor
Re: Valve guide seals, which brand is best? [Re: motero] #1065608 10/30/13 03:59 PM
mxmikie Offline
$45.00 with a $125.00 deposit it comes with the air hose adapter
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6388 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-10-24 03:22:31 UTC
