Water pump on v6 leaking again, can I just take off the tension pulley and replace the pump? #1065713 11/01/13 11:49 PM
G
graeaglecrawler Offline OP
Everything is new but the pump is leaking again
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: Water pump on v6 leaking again, can I just take off the tension pulley and replace the pump? [Re: graeaglecrawler] #1065714 11/02/13 06:16 PM
Elbow_Greese Offline
I was able to do basically the same thing you are asking. The tension pulley for the 93-94 v6 is different than the 90-92 v6, so not sure if this will work for you.
After draining the coolant and getting back into it, I was able to remove the tension pulley, replace water pump, then slowly tighten the bolts for the tension pulley to get it back on (about a 1/4 turn on each bolt at a time).
Hope this helps.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Water pump on v6 leaking again, can I just take off the tension pulley and replace the pump? [Re: Elbow_Greese] #1065715 11/02/13 08:16 PM
G
Thanks for the reply! I have a '90. So very little of the timing belt is disturbed when just getting at the pump, is that what you are saying? Just take off the tensioner and I was going to mark the timing belt and get it to TDC just in case anything goes wrong.
Re: Water pump on v6 leaking again, can I just take off the tension pulley and replace the pump? [Re: graeaglecrawler] #1065716 11/04/13 02:27 AM
That is correct. I also put it at TDC just in case. The belt shouldn't move off the cam gears, and I was able to get the tension off the water pump enough to replace it.
Making sure no antifreeze got on the belt was kinda tricky, but it's doable.
94 2wd v6 extracab
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6013 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-10-21 17:31:07 UTC
