3.0 Cold stumble off idle? #1065894 11/06/13 06:33 AM
mike71800b Offline OP
My 89 Montero SWB automatic trans, Cranks quickly and revs cold at 1800 or so and idles down as it should when temp gauge comes up. When you first drop it in gear from high idle it bumbles for almost 1 second with the engine speed dropping to around 800 for that second then idles up to about 1k rpm smoothing out. It will stumble again just enough for the nose to drop a tad if just a tad of throttle opening, then smooths up. Feels just like a carb with an off idle flat spot would feel.
More throttle = more go with no misfiring cold or hot just as it should. Transmission shifts just as it should both cold or at running temp.
I pulled the cap and plugwires last night which looked ok, plugs looked alright as well. Not quite tan but not bleach white and no soot at all. No funny arcing under hood in the dark, nor did misting water on the wiring change anything. It seemed to have a little more stumble after all that so I ordered wires/cap/rotor/plugs/fuelfilter just because it hasnt had any tuneup parts since i had it.
Question is if the new parts list doesn't resolve this, is the stumble a telltale of a bad sensor, temp or tps?
Thanks for feedback on this guys, im sure im not the first with a stumble like this.
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 3.0 Cold stumble off idle? [Re: mike71800b] #1065895 11/07/13 01:00 AM
Remove the ICM and thoroughly clean the throttle body, especially the seat and plug of the ICM. Check for intake hose leaks especially in the accordion hose. It hasn't been cold enough here in Jawjah to be causeing this.
Re: 3.0 Cold stumble off idle? [Re: mike71800b] #1065896 11/07/13 01:40 AM
W
willwinchforfood Offline
Mine does the same thing in appx 60 deg or colder temps. Clears up after the first 30 seconds. I just ignore it. I've had the issue for years and notice no real problems it's causing.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5972 MB (Peak: 0.6514 MB) Data Comp: Off Server Time: 2026-10-22 12:15:07 UTC
