Re: rpm question [Re: geocrasher] #1066043 11/13/13 12:07 AM
SledgeHammer Offline OP
at 55mph..in 5th gear with 30's it says 3500
Unless your axles have 5.29's in them (incredibly unlikely) your tach or speedo is simply off. Speedo is easiest to check with a GPS, or even a passenger with a stopwatch and an open road, milepost markers and some basic math.
this is why I asked the question on what everyone is running because using gps at 55mph,it sounds like it is wound up at 3500 rpm.I mean it just doesn't feel like it wants to go much faster.I mean I can but I have had it near 3800 rpm at somewhere near 60 mph or so.I thought maybe this thing is just that weak...lol
Something must be just off cause I get pretty good gas mileage.
Re: rpm question [Re: SledgeHammer] #1066044 11/13/13 01:36 AM
Methinks that somethings afoot. <img src="/forums/images/graemlins/wink.gif" alt="" />
Carb issues maybe? Don't recall the history of your rig but that's high (assuming the tach's accurate).
Re: rpm question [Re: off-roader] #1066045 11/13/13 01:47 AM
plh Offline
Yea, maybe the Tach is off by 1000 RPM. Calculation says 2440 at 55 mph
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: rpm question [Re: plh] #1066046 11/13/13 02:48 AM
Math...check...exactly. <img src="/forums/images/graemlins/smile.gif" alt="" />
30 x PI (3.1416) = 94.248 (circumference in inches)
63360 (# inches per mile) / 94.248 = 672.7 tire revolutions per mile
672.7 x 4.625 (gear ratio) = 3109 engine revolutions per mile in 4th gear
Not knowing the amount of overdrive...just multiply the OD percentage by the non-OD number above.
K? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: rpm question [Re: off-roader] #1066047 11/13/13 03:14 AM
geocrasher Offline
No carb issue will affect RPM like that. This is a matter of gearing and inaccurate instrumentation. Either your speedo is off and you're really doing 70mph or so, or your speedo is off. Its one or the other. Figure out which and go from there. And, don't have a friend drive in front of you at a specific speed, because cars, and their drivers, are commonly several mph off.
http://tidbitsfortechs.com/
Re: rpm question [Re: rxinhed] #1066048 11/13/13 03:41 AM
haztoys Offline
And your tire is 'not' 30 in....Take a tape and measure from the ground to the center of the axle ..Then times (X) that number by two ..That will get you the 'real' tire size the 'rolling tire size'..No matter what the tire says on it they are always wrong on the real size
Re: rpm question [Re: rxinhed] #1066049 11/13/13 03:58 AM
plh Offline
Russell, your calculation is at 60 mph. He was referencing 55 mph which in 4th gear is 2851 RPM and 5th gear 2440 RPM KM145 is 0.856 OD in 5th
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: rpm question [Re: haztoys] #1066050 11/13/13 04:04 AM
plh Offline
Absolutely sorta correct! Tire does grow at speed. a little.
But to be at 3500 RPM at 55 MPH his tire "real" height would be 21"
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: rpm question [Re: plh] #1066051 11/13/13 05:51 AM
Yes, I calculate at 60mph for ease of calculation. Simple coefficient of 0.9167 to calc at 55mph.
Re: rpm question [Re: plh] #1066052 11/15/13 02:01 AM
plh Offline
I would like to know for the 4cy 5 speed guys,at hiway speed,say 55-60....what rpm are you turning and post tire size also. Mine seems kinda high at 60 mph.
What making you think it's high?
Check this:
DropBox - Gear Ratio RPM MPH Calculator (Excel or OpenOffice)
Updated. Now includes 5.29 rear ratio
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6469 MB (Peak: 0.7725 MB) Data Comp: Off Server Time: 2026-07-14 00:32:32 UTC
