Alternator failed #1066199 11/15/13 01:40 AM
LRJ4x4 Offline OP
First, my demise has been greatly exaggerated ! I'm still rolling in the Gen 2.5.
I'm assuming my alternator died as my volts are reading 9 on the gauge. I'm going to test it tonight when I get home.
Re: Alternator failed [Re: LRJ4x4] #1066200 11/15/13 02:19 AM
LRJ4x4 Offline OP
battery = 12.6 volts with engine off
battery = 13.8 volts with engine running
battery = 12.6 volts with engine running and high beams on
Conclusion, daylight savings killed my truck
Re: Alternator failed [Re: LRJ4x4] #1066201 11/15/13 02:47 AM
That makes another thing that Benjamin Franklin helped you with. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Alternator failed [Re: rxinhed] #1066202 11/15/13 04:23 AM
Grasscat Offline
Hey Les
Is there oil leaking onto the alternator? If so you will have to deal with that first. If no leak have the battery tested, if OK have the alternator tested, if bad have it rebuilt. It only takes a day to rebuild one if you show some tears and tell them you are in a bad way. The ones from the parts store seem to not last very long.
Sorry I can't help you. I've move further away, I'm now in Livermore.
Michael j
TreadLightly! Trainer
Re: Alternator failed [Re: LRJ4x4] #1066203 11/15/13 04:42 AM
About time we heard from you. Rock Auto is your friend. Order something from them and get to swappin'.
Re: Alternator failed [Re: JohnnyBfromPeoria] #1066204 11/15/13 05:09 AM
spencevans Offline
Don't go to Autozone or you will be swapping it out twice.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Alternator failed [Re: spencevans] #1066205 11/15/13 07:03 AM
LRJ4x4 Offline OP
I have a local rebuild shop. Looks like a bear to get at, fan shroud, fan, airbox, two serpentine belts. Looks like I'll have to drop the skids to get at the bottom tensioner. Not exactly 2.6 room under the hood.
Re: Alternator failed [Re: LRJ4x4] #1066206 11/15/13 12:58 PM
Les, I just did mine. Yes, drop the front skid, then you can loosen the bolt in the center of the idler pulley and then loosen the tensioner bolt and remove the belt. You don't have to remove any other belt or the fan shroud; at least I didn't, but I have a body lift and it may have made a difference, I don't know.
Take out the air box. After you remove the air filter and the top section of the box, there are three bolts that hold the bottom section in. Check the grommet thing that seals the box to the fender, as mine was distorted to the point that I re-did it with some weather strip I had laying around.
From your newfound clearance area, take out the alternator mounting bolt and the one that connects the alt to the tensioner, then remove the wires (you did remove the negative battery cable first, didn't you?). In the course of trying to get the alternator out through the top you may have to remove a power steering line bracket and move the shield around the top of the power steering belt at the top. It's tight in there.
I put in a rebuild, because I'm crazy like that. I kept my old one and may have it rebuilt, but I bought some time at any rate.
Good to see you back on here.
Re: Alternator failed [Re: JohnnyBfromPeoria] #1066207 11/15/13 04:46 PM
Les,...
What Johnny B said.
How are you doing?
Re: Alternator failed [Re: off-roader] #1066208 11/19/13 01:21 AM
Rontopia Offline
yep - skid plate and yep only have to loosen one belt. air box has to go and then the 2 bolts holding the alt..
ALSO RELLAY IMPORTANT. disconnect battery. im sure you already know this, but no one else said it so now I feel like i have actaully added to the conversation <img src="/forums/images/graemlins/smile.gif" alt="" />
did mine over the weekend.
one other thing. the numbers in your 2nd post. is that what you want or what your getting with a meter at the battery?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6412 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-07-09 13:29:52 UTC
