dual battery setup 1 gen lwb montero #1066565 11/24/13 06:03 AM
1
1morebike Offline OP
my land cruiser had duel batteries and i loved having that extra battery and want to do the same with montero. i know how to do the wiring but i was wondering if anyone else has this setup and where they put the extra battery?
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: dual battery setup 1 gen lwb montero [Re: 1morebike] #1066566 11/24/13 07:21 AM
I don't recall if yours is and RS or LS model. Either way, the second battery mount location is on the driverside front inner fenderwell immediately behind the headlight. On the LS, this is where the headlight washer reservoir is located. There may also be interference from other items.
Others will chime in.
Re: dual battery setup 1 gen lwb montero [Re: rxinhed] #1066567 11/24/13 07:48 AM
1
no headlight washers so i should be good. is there battery box people are using?
Re: dual battery setup 1 gen lwb montero [Re: 1morebike] #1066568 11/24/13 04:24 PM
Oso Offline
gen 2 battery tray fits nicely.
a/c lines and cruise control unit will also be in the way - if you have those. I tried this mod, removed the hw pump, and then ran into the other items. There are good threads on this...
Re: dual battery setup 1 gen lwb montero [Re: Oso] #1066569 11/25/13 02:21 AM
Monteropr Offline
I did it, it is great and a cheap build,
I bought a boat battery box, a jumper cable
removed the clamps and welded the worked very good
main battery is in engine bay, the other is beside the driver seat
I have pictures if you like
58 (283) Corvette top flight
67 (427) Corvette top flight
69 (302) Camaro
70 (440) Chevy
36 Dodge Brothers Hot Rod
30 Ford Hot Rod
07 Dodge Ram STR
93 Montero
Re: dual battery setup 1 gen lwb montero [Re: Monteropr] #1066570 11/25/13 10:39 AM
Of course we would like pictures. Thanks.
Re: dual battery setup 1 gen lwb montero [Re: Oso] #1066571 11/30/13 05:07 AM
1
no cruise but i do have ac...it might fit but it will be tight, ill let you know.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6166 MB (Peak: 0.6907 MB) Data Comp: Off Server Time: 2026-06-07 09:09:55 UTC
