Name that seal? #1067041 12/11/13 11:38 PM
motero Offline OP
Fits on the inside of the spindle, rides on the cv shaft. Is it going to be a dealer only part?
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Name that seal? [Re: motero] #1067042 12/12/13 12:16 AM
plh Offline
Spindle hub seal. NATIONAL Part # 710146 - Rockauto $4.67 each
Wheel Inner at Knuckle. BECK/ARNLEY Part # 0523448 - Rockauto $2.77
I think both of these are the same seal.
MB160850
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Name that seal? [Re: motero] #1067043 12/12/13 12:18 AM
Mo, I know which one you mean, but I can't find it pictured in ASA, either alone or as part of a kit. It's the bronze-looking washer-like piece that has the serration-sort-of grooves in it, right? Junkyard only, maybe. Strange.
EDIT, I posted after plh, so I looked that part up and it's not what I was thinking of. Timken calls it the knuckle seal. Does that look right to you, motero?
Re: Name that seal? [Re: JohnnyBfromPeoria] #1067044 12/12/13 12:20 AM
plh Offline
if its the brass part JBP is referencing - probably junk yard, or...
MB160671 Mitsubishi V31 V32 V33 SPACER,KNUCKLE ( Brass )
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Name that seal? [Re: plh] #1067045 12/12/13 12:30 AM
Canyonero Offline
Or are you referring to this one? Part # MB526395 in ASA. Trying to find a cross reference.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Name that seal? [Re: JohnnyBfromPeoria] #1067046 12/12/13 02:23 AM
I think that bronze thingy is a wear bushing to take any side load from the cv shaft shoulder. The cv axle moves in and out, and if it actually bore on the seal, it would toast it quickly. The serrations are for lube retention.
Re: Name that seal? [Re: plh] #1067047 12/12/13 06:04 AM
motero Offline OP
It looks like the spindle hub seal, good find Paul.
Thanks dudes.
01 montero limited
Re: Name that seal? [Re: Canyonero] #1067048 12/12/13 09:23 AM
plh Offline
SKF Part # 22841 Grease Seal - Rockauto $9.23
BECK/ARNLEY 0523374 Grease Seal - Rockauto $2.56
Same part
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Name that seal? [Re: plh] #1067049 12/12/13 01:37 PM
I must not have thought to look in that ASA section, as I didn't see it shown anywhere in the schematics I was looking at. Guess I should get me a couple of those...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6288 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-07-14 10:49:54 UTC
