Brake upgrade #1067155 12/16/13 07:05 PM
Sandhog1234 Offline OP
I own an '88 Trooper II and want to upgrade the brakes (calipers & rotors ). Was the factory upgrade in 1992, if not, which year?
Politics is the last refuge of scoundrels
Re: Brake upgrade [Re: Sandhog1234] #1067156 12/16/13 08:27 PM
Jim_Paget Offline
I am not sure what you mean by the factory upgrade. The body style for your rig ran through 1991. The axle in the 1992 is the same axle as yours (Isuzu 12-bolt). The width of the axle did change in 1992 and again a couple of years later.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Brake upgrade [Re: Jim_Paget] #1067157 12/16/13 08:55 PM
I can see where my wording, "factory upgrade ", could be misleading. What I wanted to know, are the '92 calipers and rotors larger and do they fit my '88 Trooper II axles?
It's been a few years since I was a member of this great site. I got my 2nd felony DWI 03/01/13 and will be without a license for a number of years, during which time I will endeavor to custom build my Trooper.
It only has 60,000 original miles on it.
I did search the site for my answer.
Thank you,
Michael
Re: Brake upgrade [Re: Sandhog1234] #1067158 12/17/13 01:45 AM
Jim_Paget Offline
My memory is that the newer generation Troopers had 16" wheels rather than 15s, so I am guessing that the newer calipers won't fit inside the 15" wheels. However there certainly is now reason that you can't run the larger wheels on the older body. Craig Eldredge ran 16s on his 90-91 rigs.
Jim Paget
www.rrr4x4.com
Re: Brake upgrade [Re: Jim_Paget] #1067159 12/17/13 03:26 AM
That's a bummer as I have 5 mint condition, factory issue aluminum wheels with Cooper 31X10.50s on them with less than 5,000 Miles on them. Guess I'll just have to live with 15" for now. I've got plenty of other mods to address. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Brake upgrade [Re: Sandhog1234] #1067160 12/22/13 10:09 AM
Ed Mc Offline
I did the "Big Brake" mod to my '90 Troop with transplanted 3.4 V6, and the later-model calipers fit my 15" Snowflakes.
The calipers do come quite close, but they don't rub. And if you did happen to have any issues at all, it's nothing that a set of 1/4" aluminum wheel spacers wouldn't fix.
I heartily recommend the brake upgrade, it's a nice improvement in stopping power. And for anyone who already needs to do a brake job, it's a good excuse to get on with it!
Cheers & Merry Christmas..........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Brake upgrade [Re: Ed Mc] #1067161 12/22/13 01:21 PM
Thank you very much Ed. Jesus is the reason for the season. Merry Christmas to you and to everyone at 4X4 Wire.
Re: Brake upgrade [Re: Sandhog1234] #1067162 12/24/13 05:09 PM
Ed, Calmi has two offerings for spacers. 1.25" and 1.5" thickness. Your recommendation was. 25". Are the Calmini spacers too thick? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Brake upgrade [Re: Sandhog1234] #1067163 12/24/13 09:04 PM
Jim_Paget Offline
I just found a number of sources with a Google search. A six-lug pattern for Toyota or Chevy is the same as the one on the Isuzu.
Jim Paget
www.rrr4x4.com
Re: Brake upgrade [Re: Jim_Paget] #1067164 12/24/13 09:11 PM
Again, I really don't want to get away from my Isuzu factory aluminum wheels. I believe using the spacers (for now ) will suffice. But thank you for responding and have a very Merry Christmas. Jesus is the reason for the season.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6374 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-06-22 07:35:38 UTC
