Engine interchange 6G74 #1067183 12/16/13 07:22 PM
Skjeflo Offline OP
Since my 97 LWB ate its engine a while ago I've been seeking a newer engine. Found on from a 2000 Sport. Both are 3.5L 6G74 engines. What I'm wondering is if these will interchange easily or would I be looking at modding lots to get it to fit?
I know I'll have to swap over almost all the accessories, just wondering about the basic swap?
97 Montero
90 4-Door Montero RS -- R.I.P.
Re: Engine interchange 6G74 [Re: Skjeflo] #1067184 12/16/13 09:05 PM
mitsumonki Offline
Just started this on my 95 SR...
Doesn't look good. I don't think there is enough clearance for the SOHC pan and the DOHC does not fit on the SOHC. Might need a custom oil pan.. I'll find out as soon as I put the engine in the truck. And even if the pan fits not sure the oil filter will as its on the driver side and DOHC was on pass. with my oil cooler. Which I guess I cant hook up without more custom work.
But other then the pan/pump seems doable but I'm working with a SR which has coils already if you have a distributor thats another story.
Re: Engine interchange 6G74 [Re: mitsumonki] #1067185 12/17/13 04:02 AM
TainterRacing Offline
mmmm both of thos I think should just go in with out much work at all 95 and 97 both had the 3.5 sohc options.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Engine interchange 6G74 [Re: TainterRacing] #1067186 12/17/13 10:13 PM
mitsumonki Offline
Nope. SOHC pan doesn't fit. Here's the pan sitting on the front axle and you can see the motor mount isn't hooked up.[Linked Image]
Re: Engine interchange 6G74 [Re: mitsumonki] #1067187 12/18/13 03:43 AM
mmm change the pan??? or you may be able to beat on it a bit.
Re: Engine interchange 6G74 [Re: TainterRacing] #1067188 12/18/13 05:05 AM
That's all it takes to get a Mighty Max 2.4 to fit in an '86 Montero SWB. Sledgehammer engineering.
Re: Engine interchange 6G74 [Re: JohnnyBfromPeoria] #1067189 12/18/13 11:42 PM
mitsumonki Offline
Don't think I can hammer this much room.[Linked Image]
Re: Engine interchange 6G74 [Re: mitsumonki] #1067190 12/18/13 11:57 PM
Can you set the motor up a bit higher?
Re: Engine interchange 6G74 [Re: TainterRacing] #1067191 12/19/13 12:25 AM
mitsumonki Offline
I think so there is plenty of room in there now that its SOHC. But how? Should I put spacer under the mount? between the mount and bracket? Will doing this bring them to close together and mess up the mounts? So I have to raise the mounts up and out?
Re: Engine interchange 6G74 [Re: mitsumonki] #1067192 12/19/13 02:08 AM
ryany Offline
My DOHC has an upper and lower oil pan - is the SOHC the same way? If the lower oil pan doesn't interchange then maybe you need both of them to make it fit.
95 Montero SR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6362 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-06-07 09:06:23 UTC
