How to get a 33x12.5 tire on the Rear Tire Rack 89SWB
#1067229
12/17/13 05:21 PM
So do I have to extend the rear spare tire carrier with longer bolts to get the 12.5 width to fit?
- what length bolts? and spacers?
- yes I looked in the archives
89 V6 SWB OEM Sunroof RPW Headers & Custom Exhaust 15" Toyota 4Runner Chrome Rims 33X12.5 Goodyear Wrangler Duratrac Stainless Steel Lugs
85 2.6 Montero (RIP) <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: How to get a 33x12.5 tire on the Rear Tire Rack 89SWB
[Re: Bubba]
#1067230
12/17/13 06:40 PM
Since the lug bolts are long enough you just need to put washers between the new rim and the mount itself... unless you used wheels with a really deep offset.
[Re: Bubba]
#1067231
12/17/13 09:41 PM
I put some 2" square tubing under the spare mount withlonger bolts.works great, clears the wiper, no squeaks on the body.
[Re: Bubba]
#1067232
12/17/13 10:39 PM
Alloys or steelies? You can flip a steelie over.
[Re: MontyMcV]
#1067233
12/18/13 02:33 AM
Put washers between the mount and the body?
Is the tire hitting the body, or is the rim not deep enough to get you enough lug on the mount?
[Re: JohnnyBfromPeoria]
#1067234
12/18/13 03:03 AM
He has deep Toyota wheels, probably 4.5" backspace or better.
[Re: rxinhed]
#1067235
12/18/13 03:27 AM
Since the tire is heavy I would think that the more mating surface between mount and body as well as mount and wheel would be best.... Aluminum wheel spacer?
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
[Re: tonygon]
#1067236
12/18/13 05:09 AM
I hang 33 x 12.5's on the back of a couple of rigs and have even been hit in the back by a couple of vehicles without serious damage, That is just another tough area of these trucks. Six bolts hold the carrier in place. Space out whatever you need to, it won't hurt anything...probably.
[Re: Bubba]
#1067237
12/18/13 05:50 AM
Interesting that you all seem to prefer spacing out the mount itself. That means extra work removing the mount to add spacers when instead you can add spacers to the lug bolts and space the rim farther from the body and mount instead. <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: off-roader]
#1067238
12/18/13 01:14 PM
I just turned my 31's around backward. Mounts fine.
The kids called my wife's Montero the "Momtero". So, they called mine the "Dadtero".
