1995 SR Parts Needed
#1067512
12/24/13 08:16 PM
Replacing the timing belt on my 1994 Montero SR (3.5L 6G74)and discovered that most of the 10mm bolt holes that hold the water pump to the water pump housing are stripped. Looked in ASA and it doesn't show the part number for the housing that the water pump goes into, only the water pump itself. The bigger 14MM bolts that go into the engine block are fine. Would rather be proactive and have the part available because I figure this will be a problem down the road if I ignore it. Is this a part number anybody has and that I order a replacement for or am I going to have to find one in a junk yard?
Another part I discovered a stripped bolt hole on was the power steering pump, I found the part number for it (MB922960) and this was already on my list of things to replace because it seems to leak oil all over that side of the engine anyway.
Sean - Just a few miles south of Hell, AZ
[color:"blue"]Current Project: 1994 Montero SR recently not smoking, in need of offroad mods.[/color]
Re: 1995 SR Parts Needed
[Re: Torchwood]
#1067513
12/24/13 09:42 PM
[Re: Monty]
#1067514
12/24/13 10:11 PM
The ASA part image shows the whole pump set with gaskets, front and back halves. I've bought aftermarket with both, too.
[Re: fasteddy]
#1067515
12/25/13 06:31 AM
i have a water pump housing send your mailing address
[Re: mxmikie]
#1067516
12/30/13 01:16 PM
pm sent did you get it ???
[Re: Torchwood]
#1067517
01/04/14 03:10 PM
Another part I discovered a stripped bolt hole on was the power steering pump, I found the part number for it (MB922960) and this was already on my list of things to replace because it seems to leak oil all over that side of the engine anyway. hey buddy i sent you a water pump housing did you get it ???
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6108 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-10-21 20:47:15 UTCValid HTML 5 and Valid CSS
