Locking exhaust manifold nuts #1067684 12/31/13 10:22 PM
Mudraider Offline OP
Frustrating <img src="/forums/images/graemlins/angry.gif" alt="" /> Having to install a couple of Heli-coils on the 88 that I found a header to replace the cracked stock exhaust manifold. Following faseddy's advice, I went to get some new locking exhaust nuts, which I have found to be important with headers. Checked with Advance, Discount, O'Reilly's, and NAPA. Pretty much looked at like I had an eye on my forehead . <img src="/forums/images/graemlins/cyclops.gif" alt="" />.I even had a girl at Discount recommend Nylock nuts. Really???? Anyone know a part number to offer one of these places. None of them use books anymore, and the effin computer is is to cumbersome. Any ideas? I'm gonna use locking washers with the original nuts, until I can find some. Probly order some from my original VW supplier. Sometimes this triple diamond stuff is so annoying.
Re: Locking exhaust manifold nuts [Re: Mudraider] #1067685 12/31/13 10:40 PM
jwthemechanic Offline
I got mine here. Happy New Year!!
http://www.enginemachineservice.com/conquest.html
"Turbobitchero" (named by jealous wife) 87 swb base, 89 starion intercooled turbo engine, Bouncy seat, posi in rear, "miller locked" in the front with manual hubs, 3" BL, 305/70/16 bfg's. Sponsored by IAWDLR Racing
Re: Locking exhaust manifold nuts [Re: Mudraider] #1067686 01/01/14 02:39 AM
Auto parts stores are horrible for metric hardware. Ace is the place...stainless, brass, aluminum, grades 7 - 8 - 10, are in the bins at three of the four stores near me. The one loner is outside the tractor area.
Re: Locking exhaust manifold nuts [Re: rxinhed] #1067687 01/02/14 01:56 AM
These are special. The threads constrict at the top of the nut, crating a friction lock on the stud without plastic inserts. We had an Ace with a great selection of metric, closed after a bad fire. I've heard they reopened, but not sure where
Re: Locking exhaust manifold nuts [Re: fasteddy] #1067688 01/02/14 02:28 AM
FE, when I worked auto parts, we had two different type of self-locking nuts. The first was a simple squeeze on opposite sides. The second appeared as if the nut was held in place and punched from three directions at about a 60 degree angle. This produced a hilly-looking nut that was definitely directional.
The English cars I've had mostly used brass nuts on the exhaust side, and few had lock washers. Due to the different expansion characteristics of the two metals (steel studs / brass nuts), the exhaust was kept tight when heated. I've used this arrangement on a Dodge W200 that I installed Thorley headers on, as well.
Re: Locking exhaust manifold nuts [Re: rxinhed] #1067689 01/02/14 06:12 AM
mxmikie Offline
check it out.... you can use your stock nuts just use cherry mylanta on the threads and they will not come loose it has to be cherry the regular mylanta wont work ........its a long story but it works great
Re: Locking exhaust manifold nuts [Re: mxmikie] #1067690 01/02/14 01:38 PM
Uh, ok? Going to use lockwashers, until I can get up to the VW shop this weekend.
Re: Locking exhaust manifold nuts [Re: Mudraider] #1067691 01/02/14 05:44 PM
mxmikie Offline
post #12 check it out
Re: Locking exhaust manifold nuts [Re: Mudraider] #1067692 01/03/14 05:45 AM
haztoys Offline
Use Mitzu EVO exhaust studs and nuts.... And open the holes on the manifold so it can move around under heat and cooling so it will not break the studs off ... Any and all generic nuts and studs from a auto parts store are junk..
Re: Locking exhaust manifold nuts [Re: haztoys] #1067693 01/05/14 03:13 AM
Finally found a counterman that didn't rely on puter. He looked thru a Dorman book, found it. He is getting me the part #, I'll post it when I get it.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6416 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-07-15 08:12:00 UTC
