Re: 2000 - Fog lights go off when high beams are on [Re: cheesegrater] #1067839 01/06/14 10:17 PM
TainterRacing Offline
Sorry, carry on.
I don't drive around with other cars around with the high beams. And On top of that the fog lights are aimed down at about 8*
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: 2000 - Fog lights go off when high beams are on [Re: TainterRacing] #1067840 01/07/14 01:57 AM
1
1986powerram50 Offline
On my 05 f150 you could ground a relay and make the fog lights stay on all the time. I'm sure the same could be done with the montero with a little bit of thinking.
--keRby
Ad Inexplorta
Re: 2000 - Fog lights go off when high beams are on [Re: 1986powerram50] #1067841 01/07/14 06:26 AM
It really depends on how it was wired up.
Re: 2000 - Fog lights go off when high beams are on [Re: off-roader] #1067842 01/07/14 06:53 AM
In the 98 fsm, it seems that fogs are not restricted to low beam only, but it does seem the fog light switch also turns on the tail lights. I had a euro spec Mercedes 280TE gas wagon that had one fog tail light and one reverse light, fog light came on with the front fogs, and those fogs only worked in low beam. I had the euro spec headlights, though, reinstalled after the grey market inspection, and you didn't need any additional high beam illumination with those big old H4 bulbs...
Re: 2000 - Fog lights go off when high beams are on [Re: fasteddy] #1067843 01/07/14 03:15 PM
F
Fujisawa_Rob Offline OP
I'll have to look at it again. I think it shares the same power as the the taillight relay, but I am not aware of any rear fog mode. I'd like to add a rear fog light or two, it gets foggy in Florida more than you'd expect.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: 2000 - Fog lights go off when high beams are on [Re: Fujisawa_Rob] #1067844 01/08/14 12:00 AM
WIthout opening the 98 wiring diagram again, as I remember, the fog light switch enables a ground path which branches to both turn on the fog light power via a relay and also the ground path for the tail light relay enable, so the tail lights come on with the fog lights. I see no wiring connection to the headlight circuits, but they may be on the headlight diagram which I did not examine, and in any case, the 2000 may be different.
Re: 2000 - Fog lights go off when high beams are on [Re: fasteddy] #1067845 01/08/14 03:55 AM
87Montero Offline
Interesting. I do not get a rear fog with my front ones on my '99.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6250 MB (Peak: 0.7359 MB) Data Comp: Off Server Time: 2026-10-22 07:40:43 UTC
