87 Monty SWB coil question #1067889 01/08/14 05:00 AM
X
XJ4PJ Offline OP
I'm hoping someone can help me out with this. I am replacing my coil do to what looks like corrosion (extreme discoloration)on the distributor wire port. I thought I was doing OK taking notes and all, but, just like the proverbial homework excuse, "the dog ate my paper" I guess I shouldn't have used my burrito wrapper to make notes on.
Anyways, I was hoping someone with an 87' could take a picture of their coil or tell me which lead go's where. Thanks guy's
87' Monty bone stock (at the moment)
91' XJ waggy D44, spooled 4 link w/ coil overs front, Ford 9" shortened and spooled rear, working on a cage w/ buckets front and rear.
Re: 87 Monty SWB coil question [Re: XJ4PJ] #1067890 01/08/14 06:38 AM
Struc Offline
Drop me your email in a PM, and I'll send some over.
Curt Shambeau
87 Mitsubishi Montero SWB (Turbo G64b wideblock conversion soon)
Re: 87 Monty SWB coil question [Re: Struc] #1067891 01/08/14 11:05 PM
From the 87 fsm, vol 2 page 8-53, Ignition system:
To coil - : WL/B, 1.25L
To coil + : unknown color wire from top of resistor
To bottom of resistor: 2BW, 1.25BW
to top of resistor: 2BW
color codes:
B=black
W=white
L=blue
R=red
The numbers represent the thickness of the wire, bigger number is fatter wire in mm^2 x-section.
2BW will be hot in ign run, 2BR is hot in ign start only.
1.25BW and 1.25L come from the dizzy.
WL/B goes to tach.
The resistor drops the coil voltage in run to prevent coil overheating. If you use an aftermarket Accel Supercoil, you can delete the resistor and run 2BR and 2BW straight to the coil+.
Re: 87 Monty SWB coil question [Re: fasteddy] #1067892 01/09/14 03:19 AM
X
XJ4PJ Offline OP
Thanks Fasteddy, I picked up a Chiltons that covers 83 thru 85 and it didn't have any info on the coil. What manual is the "fsm"? I've printed out your legend and will give it a try this weekend. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 87 Monty SWB coil question [Re: Struc] #1067893 01/09/14 03:20 AM
X
XJ4PJ Offline OP
Thanks Curt, I sent you a PM with address.
Re: 87 Monty SWB coil question [Re: XJ4PJ] #1067894 01/09/14 05:56 AM
geocrasher Offline
Step 1) Use the Chiltons manual for kindling
Step 2) http://mitsubishilinks.com
Step 3) ??????
Step 4) Profit!!!!
http://tidbitsfortechs.com/
Re: 87 Monty SWB coil question [Re: geocrasher] #1067895 01/09/14 06:33 AM
Yes, it is much too abrasive for the only other possible use.
Re: 87 Monty SWB coil question [Re: fasteddy] #1067896 01/09/14 06:44 AM
Oso Offline
[/quote]
Yes, it is much too abrasive for the only other possible use. [/quote]
nah, he's in california and probably used to a high fiber diet. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7248 MB) Data Comp: Off Server Time: 2026-06-07 05:46:09 UTC
