Need some advice on 95 SR no spark issue! #1068003 01/12/14 02:35 AM
tonygon Offline OP
I do appologize if this has been covered, but i would like to get an idea. Im bing offered a 95 sr for cheap. The issue with the truck is lack of spark. I know of some possibilities but know theres more. Can you knowlegeable guys just throw ideas out there. Im trying to visualize the worst case scenario to see if this truck is worth buying. Thanks in advance!
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068004 01/12/14 03:04 AM
Worst case, bad ecu. Next, bad power transistor trio. Next, all coils bad (only if total no spark, not just no spark to some cylinders). Next, bad crank/camshaft positions sensors (fairly common). These are about the only no spark causes except a bad connection somewhere.
Re: Need some advice on 95 SR no spark issue! [Re: fasteddy] #1068005 01/12/14 04:10 AM
tonygon Offline OP
Thanks fast eddy for your fast response. Your great answer is more than appreciated. So what kind of pocket damage would one be looking at for a bad ecu? Oh btw, truck died while running on the freeway if that helps you lean towards any particular scenario. Timing belt is on nice and tight and everything turns fine. I know the sound of a broken timing belt and its not that. Thanks again!
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068006 01/12/14 01:32 PM
P
pcc Offline
Rebuild here: http://avproecm.com/index.htm
I think mine was $168 few years back. You should be able to do a self test on the ECU to determine if bad.
Re: Need some advice on 95 SR no spark issue! [Re: pcc] #1068007 01/12/14 03:31 PM
mxmikie Offline
i have a good ECU you can have for $65.00 shipped
Re: Need some advice on 95 SR no spark issue! [Re: mxmikie] #1068008 01/12/14 05:39 PM
tonygon Offline OP
Thanks, guys for the input and the offer! I will pull the tigger on this purchase and start troubleshooting soon after. I'll have that used ecu in mind in case thats my problem.
Re: Need some advice on 95 SR no spark issue! [Re: mxmikie] #1068009 01/12/14 05:52 PM
tonygon Offline OP
Thanks for the input, guys. I will purchase the truck and start troubleshooting soon after. I'll have that used ecu in mind in case i need it!
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068010 01/12/14 06:04 PM
Monty Offline
you can part it out, sell me the springs, locker, and air pump <img src="/forums/images/graemlins/smile.gif" alt="" />
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Need some advice on 95 SR no spark issue! [Re: fasteddy] #1068011 01/12/14 10:19 PM
Jay Ayala Offline
I'm inclined to agree with fasteddy. I had a similar situation on my 1989 3.0L SOHC 12 Valve engine once. Also on a highway situation, its kind of a funny coincidence now that I think about it. It turns out that I didn't plug in the connector to the power transistor all the way and it came loose. After trying to restart it on the side of the highway a couple times, I popped the hood and it took me about 5 minutes of looking at different things before I spotted the connector had come loose (had not completely come off, that's why I didn't notice immediately).
I reconnected it and it started right up.
The power transistor can be seen in this image. It isn't labeled but can clearly be seen just below and to the left of the ignition coil. Small black rectangular block with the connector attached to it.
Re: Need some advice on 95 SR no spark issue! [Re: Jay Ayala] #1068012 01/13/14 12:06 AM
Jay, his setup is different. He has 3 coils firing 6 plugs using waste spark system. THe coils are triggerd by an assembly with 4 power transistors in it, three of which fire the coils and the 4th (IIRC) turns the power on to the PT's. I don't remember what it looks like off hand, or exactly where it is, but it's all in the 92-96 fsm...
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6393 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-07-14 12:36:10 UTC
