Suggestions for painting manual hubs.... #1068051 01/13/14 05:13 AM
off-roader Offline OP
Gonna be painting my hubs. Any diy paint/primer recommendations? I'm talking rattle can diy.
Can they simply be clear coated?
If not then I'm thinking an epoxy primer with a rustoleum paint on top. Any suggestions?
TIA!
Re: Suggestions for painting manual hubs.... [Re: off-roader] #1068052 01/13/14 05:19 AM
Do you like powder coating instead, like Russ did on his?
Otherwise, thorough cleaning and a non-rattle can epoxy paint like dishwashers, washers, etc. could be a good compromise.
Re: Suggestions for painting manual hubs.... [Re: rxinhed] #1068053 01/13/14 06:10 AM
Cause I didn't want to wait for them... Thought a rattle can option might be doable.
Was it wabfab who Russ recommended?
Re: Suggestions for painting manual hubs.... [Re: off-roader] #1068054 01/13/14 06:59 AM
Ah, yes. The Wait. <img src="/forums/images/graemlins/lol.gif" alt="" />
I'd clean the visible surfaces best. If you have the hubs off and disassembled, use a fine steel wool and WD40 to clean up loose bits. A good cleaning in solvent to remove the WD40 and you're about ready. Krylon sells a spray epoxy is several colors. I used some red to create a candy finish on a Schwinn bike many many many years ago.
Your suggestion of clear is good for this. Make sure to leave adequate cure time between coats. Warm and sunny day on an asphalt paved surface can act like a kiln, too.
Re: Suggestions for painting manual hubs.... [Re: rxinhed] #1068055 01/13/14 01:42 PM
Grasscat Offline
Why paint them? They look good when clean up and you won't have that HEY look at me look. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Suggestions for painting manual hubs.... [Re: rxinhed] #1068056 01/13/14 01:46 PM
Grasscat Offline
Why paint them?
Michael j
Re: Suggestions for painting manual hubs.... [Re: Grasscat] #1068057 01/13/14 03:22 PM
Lloyd Swartz Offline
Only posers paint them! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Suggestions for painting manual hubs.... [Re: Grasscat] #1068058 01/13/14 03:43 PM
So they don't rust like they were when we cleaned them up originally! Duh! <img src="/forums/images/graemlins/wink.gif" alt="" />
Anyway, I was thinking of either painting them with a simple clear coat or silver...
Re: Suggestions for painting manual hubs.... [Re: off-roader] #1068059 01/13/14 06:06 PM
I plan on painting mine black to match my rims. Then the same with the center of the rear axles. I don't have my center caps...
Re: Suggestions for painting manual hubs.... [Re: MontyMcV] #1068060 01/13/14 07:46 PM
monte3 Offline
I polished my Asians and there isn't the slightest sign of any rust in 3 months.(of course, we're in the <img src="/forums/images/graemlins/evil.gif" alt="" /> desert)
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6421 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-10-22 12:15:32 UTC
