3.0 oil cooler system
#1068133
01/15/14 03:50 AM
After owning a 93 for 7 years, I just realized there is an oil cooler unlike anything I have ever seen. (Shows how little I have to do to keep her running). Anybody out there have a suggestion to go to a more efficient, air cooled system? Figure there is a set of fittings to pull the round cooler, reroute or block off the thermostat bypass hose and go to a conventional radiator. Pros? Cons? Please advise. Thanks, Bill
trafdlo
Re: 3.0 oil cooler system
[Re: wsquaredodie]
#1079322
10/16/15 03:55 PM
I know I'm a little late...but I don't think you'll git a more efficient setup with an air cooled setup than the water cooled oil cooler. Not sure on the temperature of the coolant when it gits pulled from the bottom of the radiator and pumped directly into the oil cooler. Fluids are up to 200 times more dense than a gas as there is more thermal capacity in a fluid than there is in a gas. Someone versed in fluid dynamics may be able to tell you how much more air flow and temperature differential you will need to exceed the capabilities of fluid flow.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5890 MB (Peak: 0.6370 MB) Data Comp: Off Server Time: 2026-10-24 23:54:52 UTCValid HTML 5 and Valid CSS
