Re: Fried connector, Help! [Re: RoryTek] #1068161 01/17/14 04:43 AM
ryany Offline
I think the reason it fried was because I left the headlights on until the battery drained dead.
That would not have caused the connector to melt. Leaving the headlights on just creates a normal current draw which will eventually drain the battery if the engine isn't running to charge the battery. Something abnormal caused that damage, and it would be a good idea to diagnose what caused it before reconnecting it.
95 Montero SR
Re: Fried connector, Help! [Re: RoryTek] #1068162 01/17/14 05:54 AM
Struc Offline
My solution:
Fuse Box on Amazon
Mounted near the battery and fed with a 8awg wire. Makes it handy to add a couple extra things too.
Curt Shambeau
87 Mitsubishi Montero SWB (Turbo G64b wideblock conversion soon)
Re: Fried connector, Help! [Re: rxinhed] #1068163 01/17/14 06:33 AM
RoryTek Offline OP
Thanks RX, I think what caused the high current flow was that the terminal was corroded and it might of happened a long time ago since I never saw that of the link.
Re: Fried connector, Help! [Re: Struc] #1068164 01/18/14 01:35 AM
plh Offline
My solution:
Fuse Box on Amazon
I used this one Amazon ATC Fuse Panel. Instead of fusses I headed to Napa and bought bulk fusible link (3 different gauges), cut to similar length as old part, then crimped on blade ends. Has worked fine for 5 years. You can google the Mitsubishi fuss link wire color to cross reference it to the correct diameter. Napa colors don't match - but gauge (Mits calls it mm2) is what is important.
Mits Color and Fuze Link Wire Size
Brown 0.3
Green 0.5
Red 0.85
*Black 1.00 (diesel glow plug circuit)
Black 1.25
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Fried connector, Help! [Re: plh] #1068165 01/18/14 10:24 PM
Struc Offline
I have the larger version of that on my boat - works great!
Curt Shambeau
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6125 MB (Peak: 0.6946 MB) Data Comp: Off Server Time: 2026-07-15 08:24:18 UTC
