Transmission Lockup - where to next? #1068179 01/17/14 10:02 PM
V
vectorsc Offline OP
I am getting a lockup failure code from my TCU, and then lockup is disabled after that. I have done the following:
1. Replaced Transmission with a super low mileage unit from a wreck.
2. Replaced Torque converter with a new one at that time.
3. Replaced solenoids for valve body.
I'm wondering if this isn't some sort of issue with fluid flow through my cooling system or perhaps its my TCU?
What would you folks check next?
1999 Montero Gen 2.5
Re: Transmission Lockup - where to next? [Re: vectorsc] #1068180 01/17/14 10:54 PM
Temp sender on engine.
Re: Transmission Lockup - where to next? [Re: JohnnyBfromPeoria] #1068181 01/17/14 11:48 PM
V
vectorsc Offline OP
I don't believe that's possible as the issue - the temp sender tells the TCU that operating temperature has not been reached. When that happens, the TCU won't command the lockup solenoid.
However, it won't be represented as an error code as the lockup won't even be asked for.
I think that my trip into the drink may have affected the TCU - I suspect it didnt like being watered.
Re: Transmission Lockup - where to next? [Re: vectorsc] #1068182 01/18/14 12:11 AM
please list your vehicle in you profile so I won't have to guess...
Re: Transmission Lockup - where to next? [Re: fasteddy] #1068183 01/18/14 03:10 AM
V
vectorsc Offline OP
Done . it was a gen II.
Looked at the computer- totally dry inside, no water signs, it was waterproofed on the PCB and such.
The lockup solenoid read 15ohms from the harness on the computer. Each time I reset the computer lockup works again for quite some time.
The last transmission and torque converter did this exact thing as well. Anyone have experience with the NSS potentially causing this? Its the only common electrical bit other than the TCU.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6054 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-05-29 18:08:40 UTC
