no 4wd #1068414 01/25/14 12:41 AM
chpfx Offline OP
Hey guys it has been way to long since I've posted anything, however I have been stopping buy once in a while to see whats going on.
Well my issue this time is my 86 4runner 22rec 5 speed manual, I lock the hubs in engage the transfer case yet no light on dash and no drive to the front axles. Stopped on ice last night and spun the tires while watching the front, no-go. Never had a problem with it until now. Come to think I had a friend replace the clutch back in the summer. Any ideas? they sure will be appreciated. Thanks.
Re: no 4wd [Re: chpfx] #1068415 01/26/14 09:05 PM
4Crawler Offline
Likely the t-case shifter was not stabbed back into the t-case in the right spot. I find I do that about half the time I have that shifter out. Best to shift into 4H, pull the shifter and look at the shift rails, should be like below:
If not, shove both forward until the slots line up and then put the shifter into those lined up slots.
Re: no 4wd [Re: 4Crawler] #1068416 01/27/14 03:36 AM
CJM Offline
yep as 4Crawler suggested .
the "no light" you suggested is the key diognossis to the problem
83 Trekker SR5
NEW Trekker forum
Re: no 4wd [Re: chpfx] #1068417 01/27/14 10:52 PM
chpfx Offline OP
Thanks guys, I'll check it out. Btw Cory how's that 2wd build going?
Re: no 4wd [Re: chpfx] #1068418 01/28/14 03:08 AM
CJM Offline
slow ...
had some shop changes over the holidays , and again the 2WD has been kicked outside in to the cold .
I am working on getting it back in though , and finally getting some serious work done on it
83 Trekker SR5
NEW Trekker forum
Re: no 4wd [Re: CJM] #1068419 01/28/14 11:28 PM
chpfx Offline OP
Glad to hear things are going well at the shop. Tonight after work I turned the heater on high, (temp. 21F and beginning to snow) and began to pull the console and shifter out. Wouldn't you know the sleeves weren't lined up as you guys said. So I slid them in line and put the handle back on and tried it out. The light still doesn't come on, old light I guess, but when engaged I could see the forward shaft rotating. Thanks again.
Re: no 4wd [Re: chpfx] #1068420 01/30/14 03:10 AM
CJM Offline
so except that pesky light, all working good then ?
83 Trekker SR5
NEW Trekker forum
Re: no 4wd [Re: CJM] #1068421 01/31/14 01:43 PM
chpfx Offline OP
No. The front axle is turning, but the front wheels aren't engaging. So I checked the hubs. The right side seemed really difficult to engage and disengage. Maybe time to clean them up as well.
Re: no 4wd [Re: chpfx] #1068422 02/03/14 03:55 AM
CJM Offline
to much " wheel bearing grease" will do that ..
may be it time to clean em up ? and make them twist easy . I just use a light coat of lubraplate on mine
83 Trekker SR5
NEW Trekker forum
Re: no 4wd [Re: CJM] #1068423 02/04/14 01:51 PM
chpfx Offline OP
Thanks Cory. As soon as the weather clears up a bit I'll do just that. While waiting I took the time and watched a few videos. Seems straight foward enough.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6387 MB (Peak: 0.7435 MB) Data Comp: Off Server Time: 2026-05-25 14:59:15 UTC
