Intermitant Gas Gauge on my 99 Gen 2.5 #1068663 02/02/14 07:35 PM
justice Offline OP
The gas gauge on my 99 is going/gone south..Pops up once in a while while driving sometimes works fine on initial start up then drops to below E and stays there most of the time, but comes up to what I believe it should be for a little while then drops back down. Seems to work more or most of the time when filled above half a tank. The tachometer recently stopped working a couple weeks ago, before the gas gauge problem. It too will kick on but very rarely. Not too sure if these two problems are related but if so I'm thinking problem is most likely in the instrument cluster..Thoughts? I'll remove and inspect and clean connections and let you guys know.
Re: Intermitant Gas Gauge on my 99 Gen 2.5 [Re: justice] #1068664 02/03/14 03:59 PM
F
Fujisawa_Rob Offline
Mine was intermittent and finally crapped out. The idiot light still works. I haven't investigated yet.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Intermitant Gas Gauge on my 99 Gen 2.5 [Re: Fujisawa_Rob] #1068665 02/04/14 08:50 AM
dirtnapper Offline
Mine kind of works. When I have a full tank its good, but 100km later its at empty. I just go by distance driven, 450ish summer time, 390ish winter.
Re: Intermitant Gas Gauge on my 99 Gen 2.5 [Re: justice] #1068666 02/04/14 04:57 PM
Grasscat Offline
Hey Justice, been awhile. Hope things are going well with you and the family.
Sounds like a ground problem in the dash area. I would start with the connector going to the dash panel. Maybe remove and plug back in a few times. From there I guess checking the connection on the tank for gas gauge and the tach, your guess is as good or better than most of us.
Michael j
TreadLightly! Trainer
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6614 MB) Data Comp: Off Server Time: 2026-10-22 12:15:37 UTC
