How to loosen/tighten crank bolt without tool #1068718 02/03/14 06:46 PM
Djunk Offline OP
Just thought I'd share this. Probably been shared and done already but I found this out after several unsuccesful attempts to torque the crank bolt without the special tool.
1. Buy the longest generic V-belt from Ace hardware
2. Cut V-Belt so it is no longer a continuous loop
3. Place V-belt into the groove on the pulley and wrap either CW or CCW over itelf.
4. Tie the other end of the V-belt to a cheater bar or other strong large metal/pipe.
5. As you rotate the crank the breaker bar with brace against frame and axle preventing the crank from moving.
6. Torque away!
This has worked for me many times and it's pretty hassle free. Hope this helps.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: How to loosen/tighten crank bolt without tool [Re: Djunk] #1068719 02/03/14 08:40 PM
Jay Ayala Offline
Nice Tip.
I'll have to take a picture later this week of my method. I don't really like it but it is effective.
It requires the engine to be on an engine stand. I actually use a bolt in the back of the crankshaft and a pipe to stop the crank from rotating. One of these days I think I'll torque too hard and break a bolt in the back of the crankshaft where the drive plate gets installed.
Re: How to loosen/tighten crank bolt without tool [Re: Jay Ayala] #1068720 02/03/14 09:21 PM
Malykaii Offline
I always liked the impact gun method. I feel like the crank bolt, unlike say a head bolt, doesn't need a perfect torque. Like the germans say goodentight... will.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: How to loosen/tighten crank bolt without tool [Re: Malykaii] #1068721 02/03/14 10:04 PM
I'm a barbarian on this. I use a breaker bar on the crank bolt, handle resting on the frame rail, and bump the starter to break it loose. I tighten it with a 4lb. dead blow hammer. Never came loose, never broke a bolt...
Re: How to loosen/tighten crank bolt without tool [Re: fasteddy] #1068722 02/03/14 10:44 PM
Oso Offline
i found a tip on here that worked well. I cut down an old belt and wrapped it around the harmonic balancer as protection, and then used a chain wrench over that. it's pretty easy too.
Re: How to loosen/tighten crank bolt without tool [Re: Oso] #1068723 02/03/14 11:20 PM
Djunk Offline OP
Nice I like this, it's pretty neat to hear all the innovative ways to get er done. Hopefully helps someone down the road. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: How to loosen/tighten crank bolt without tool [Re: Djunk] #1068724 02/04/14 06:41 AM
Devilmontero Offline
Mine broke loose pretty easy and unscrewed about 1/4" then stopped. I borrowed a 1/2"impact ratchet that I'm going to try tomorrow. I'm hoping that I don't break anything. The bolt is right hand thread correct?
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
Re: How to loosen/tighten crank bolt without tool [Re: Devilmontero] #1068725 02/04/14 01:40 PM
Yes it is, and the impact gun should work just fine.
Re: How to loosen/tighten crank bolt without tool [Re: JohnnyBfromPeoria] #1068726 02/04/14 08:43 PM
dannytuned Offline
Another impact user here. Never had a problem.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: How to loosen/tighten crank bolt without tool [Re: Jay Ayala] #1068727 02/18/14 05:59 AM
Jay Ayala Offline
...I'll have to take a picture later this week of my method. I don't really like it but it is effective..
Okay guys, I said I would take some pictures earlier and I did.
In this series of pictures, you will notice that I have the engine block on the engine stand. This is my method of how I torque the crankshaft bolt to 135 lbs/ft. The reason I don't like this method is that I always fear that I will bend the drive plate bolt or it will shear off.
Step #1. Install the Crankshaft bolt washer and bolt.
Step #2. Install one of the drive plate bolts onto the rear of the crankshaft. Make sure it is in deep enough that you get a good amount of threads engaged but not so deep that the "handle" will not fully brace against it. (You can just make out the drive plate bolt I'm referring to sticking out about an inch in this photo.)
Step #3. Using the Engine Stand's "handle", wedge it between the engine stand support posts and the drive plate bolt.
Step #4. Now I simply use my torque wrench set to 100 lbs/ft and gradually step it up to 135 lbs/ft.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6409 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-07-16 03:42:21 UTC
