'96 Montero SR 3.5 DOHC 6G74 - everything but the block #1068835 02/05/14 08:23 PM
L
lawdogg Offline OP
I have a 3.5L 6G74 DOHC longblock out of a '96 Montero SR - I'm building and stroking the block itself for a billet holset hx52 build on my Stealth. Everything else is up for sale -- well, all the little stuff is free (http://www.4x4wire.com/forums/showflat.php?Cat=0&Board=UBB69&Number=1203012&page=0&fpart=12) but I did want to get some money for:
-Heads w/ cams (sold)
-Upper intake manifold ($25)
-Throttle body ($25)
-Exhaust manifolds w/ heat shields and no EGR ($30/ea, $50 both)
-Oil pan w/ dipstick ($25)
-4 good Pistons ($80)
-Rods ($150)
-Forged Crankshaft ($450)
What IS NOT available:
-Block
-Lower intake manifold & fuel rail
-Coils (for now)
-Alternator
-Cam gears
The parts are in San Francisco, and I have pictures of everything - if interested please just ask me!
Thanks,
Ryan
1992 Dodge Stealth R/T - billet hx52 - billet 3.7L stroker
2002 Jeep WJ 4.0 - NV242 - totalled by a drunk
1994 Mitsubishi 3000GT VR-4 - 13T - 11.8 @ 116 - Modified Mag - Totalled at NEHA Hillclimb
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068836 02/17/14 09:03 PM
L
lawdogg Offline OP
Figured I'd update with some pics:
Acc. belt bracket: sold
Motor mounts:
Exhaust manis (EGR pipe sold):
Intake mani & tb:
A/C bracket:
Rods & Pistons (2 pistons are damaged, all caps & nuts matched to their rods):
Crankshaft:
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068837 02/18/14 05:37 AM
L
lawdogg Offline OP
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068838 02/22/14 12:09 AM
PA_JERO Offline
Is the egr pipe in good shape. No cracks in the flexy part. I need one of those deals. If its in good shape how much do you want for it shipped to AZ 85140?
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: PA_JERO] #1068839 02/22/14 07:33 PM
L
lawdogg Offline OP
Yes it's in great shape. I'm from the northeast so this whole California no-rust stuff is blowing my mind. But here's a close-up:
$15 shipped - I can get it out the door Monday. I can include the gaskets and bolts if you need them?
Thanks,
Ryan
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068840 02/24/14 04:22 PM
tonygon Offline
Do you have the top engine vanity cover? How much to 92114?
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: tonygon] #1068841 02/25/14 08:19 PM
L
lawdogg Offline OP
Shoot, no I don't have that top engine cover.
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068842 03/03/14 05:07 AM
TrailRaider Offline
Do you know if the heads are the same as a '95? Are they in a usable condition? If so I'll take them along with anything you want to throw in the box's if your willing to ship them to my work. Riverside, 92509 zip code. Thanks, Chad
**Also interested in the belt bracket if it's not broken**
'89 Raider V6 auto.
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: TrailRaider] #1068843 03/04/14 06:00 PM
L
lawdogg Offline OP
PM'd about the heads.
The belt bracket - you mean that BIG bracket for the acc. belts? Sorry I'm unfamiliar with the slang here, haha.
Re: '96 Montero SR 3.5 DOHC 6G74 - everything but the block [Re: lawdogg] #1068844 03/05/14 04:58 AM
TrailRaider Offline
Yep, the bracket I am referring to is the acc belt bracket. The adjustment bolt standoff on mine is broken. As long as there is no major damage to the heads and they are complete (both cams and all matching cam caps)I'll likely take them. The shop I took mine to somehow mismatched my caps from some other engine and damaged my cams in the process.Things like burned or bent valves will be replaced with a proper rebuild. Let me know when you can. Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
'89 Raider V6 auto.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6453 MB (Peak: 0.7693 MB) Data Comp: Off Server Time: 2026-06-23 22:45:01 UTC
