will the KM148 AT bolt on _mate to the 4D56T diesel? #1069150 02/14/14 12:03 PM
G
gaberc51 Offline OP
I have a '88 Gen 1 MM/dodge Raider SWB. The drivetrain is 2.6L with KM148 Auto. I'm very interested in doing the diesel swap. My current Trans is in rough shape and needs to be replaced or at minimum rebuilt. that said I would like to keep it an auto if possible if not I'll go to M/T.
welcome your thoughts / recommendations
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: gaberc51] #1069151 02/14/14 11:15 PM
spencevans Offline
If it will bolt to a 2.6L then it should bolt to the 4d56T. They share a common bolt pattern.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: spencevans] #1069152 02/15/14 03:20 AM
When you start shopping for a rebuilder for the tranny, tell them it's the same as the aw372 toyota trannies, which they are more likely to be familiar with...
The wideblock 4g64 or 4g63 motors are alternates to a diesel, much more modern than the 2.6, and capable of far more power using 4g63T parts.
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: fasteddy] #1069153 02/15/14 04:32 AM
I have a KM148 behind my 4D55T, do yeah it'll work.
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: TOASTY] #1069154 02/15/14 05:51 AM
G
gaberc51 Offline OP
Thanks for all the input. I wont be able to start this project until late may, but cant wait to get started.
I know there are some great (higher HP) alternatives to the 4D56T, but I like the oil burners. got a TDI, and a Cummins
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: gaberc51] #1069155 02/15/14 07:20 AM
spencevans Offline
There are other alternatives but the 4D56T was built to be a performance engine. From 1983-85 the Mitsubishi Turbo diesel was the fastest 0-60 production truck offered here in the states. That includes foreign and domestic pickups of all sizes and fuel types. It was the truck to have if you had a need for speed.
Spence
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: spencevans] #1069156 02/16/14 04:25 AM
TainterRacing Offline
If you want diesel that's fine... But personalty I can make as much or more power with a turbo 2.6. I personaly have made a few 2.6 with more then 300TQ by 3000rpms. Getting the tranny to hold up is a harder deal.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: TainterRacing] #1069157 02/16/14 06:54 AM
G
gaberc51 Offline OP
Big power isn't my objective with this project.
really trying to achieve 3 things:
1. Reliable DD
2. Better MPG
3. competent off-road, nothing extreme
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: TOASTY] #1069158 02/16/14 07:00 AM
G
gaberc51 Offline OP
So I assume the 4D55T Flex plate should work on the 4D56T, any issue with Torque converter / starter
Re: will the KM148 AT bolt on _mate to the 4D56T diesel? [Re: gaberc51] #1069159 02/16/14 03:32 PM
plh Offline
Diesel starter should work.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6389 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-11-02 02:59:10 UTC
