Gen 1 Montero - replace the inclinometer with something useful? #1069274 02/17/14 09:03 PM
G
GrantCee Offline OP
My '87 has a perfectly functional inclinometer - functional but useless. I'd like to take it out and replace it with something more useful, and darned anything would be more useful!
I've thought about an altimeter, vacuum gauge, compass or thermometer. I'm sure there's probably a lot of things I haven't even considered! Trouble is that I want it to look "stock" - if it's a gauge, it needs to kinda-sorta match the voltmeter and oil pressure gauges, for instance. Not necessarily perfectly, but not glaringly obviously different either.
So, tell me what you've done with the gauge in your Gen 1. Pictures would be preferred so I can see how & what you've done!
1987 Montero SWB, 2.6L, 5spd
Weber conversion
2-valve head from Engine Machine Service
"4G54 FTW!"
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: GrantCee] #1069275 02/17/14 09:07 PM
Find an orange Compass/outside temperature gauge from a pre '96 Gen 2 Montero, that'll look really close to stock.
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: TOASTY] #1069276 02/17/14 09:15 PM
Far Left, you'll need the compass sensor in the center of the dash behind the pod closest to the wind shield, the temp sensors are in the bumper endcap and under the steering column plastics. It's a pretty stand alone unit.
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: TOASTY] #1069277 02/17/14 09:18 PM
G
GrantCee Offline OP
Is that altimeter a stock Montero part? Hmmm...I like the compass/thermo, but I also like the altimeter!
Weber conversion
"4G54 FTW!"
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: GrantCee] #1069278 02/17/14 10:06 PM
Some did have altimeters. The ones I have seen are only good to something like 10k feet. So depending on where you travel...
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: GrantCee] #1069279 02/17/14 11:02 PM
Malykaii Offline
Boosting gauge? <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: Malykaii] #1069280 02/18/14 01:18 AM
d_bum Offline
I did a boost gauge on mine.
87 Raider 4d55t
89 Conquest Tsi
87 Montero SWB (for sale)
89 Montero LWB
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: Malykaii] #1069281 02/18/14 01:29 AM
Barometric altimeters are almost useless. Any time the baro pressure changes, you have to recalibrate the gauge by setting it to a known altitude. Most do a pretty good job of self adjusting for temp changes. You have to recal at least daily. Once this is done, they are pretty accurate. GPS alitmeter readings are the least accurate of the lat/long/alt measurements. When calibrated, a baro altimeter may be more accurate. I had no luck calibrating a baro altimeter off a GPS alitmeter.
THe altitude data is nice to have, but given the above, perhaps a mani vac gauge would be more useful overall, primarily as a fuel econonmy gauge.
A true magnetic vertical card compass from an aircraft application would be nice, too. I've never been wild about the electronic flux gate compasses in auto applications. The resolution can be as low as 45*. It's often useful to know if you are closer to nnw or wnw when all the compass says is nw...
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: d_bum] #1069282 02/18/14 01:31 AM
TainterRacing Offline
I have an oil temp on mine
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Gen 1 Montero - replace the inclinometer with something useful? [Re: fasteddy] #1069283 02/18/14 01:37 AM
G
GrantCee Offline OP
I'm used to using barometric altimeters in other applications, enough so that I can get good data from them, but the poor resolution of the compass is surprising. If I were to put one in I'd want it to be reasonably accurate, and 45* doesn't cut it!
As to the boost gauge suggestions: I have no boost. <img src="/forums/images/graemlins/frown.gif" alt="" />
Vacuum gauge is still in the running (like the altimeter, I'm used to using them and know how to interpret the results.) Finding one that looks good next to the other gauges may be difficult, however.
Oil temp may be a good idea - any out there that look good in the Montero decor?
Weber conversion
"4G54 FTW!"
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6390 MB (Peak: 0.7626 MB) Data Comp: Off Server Time: 2026-07-10 19:19:08 UTC
