Re: MM horn Inop
[Re: fasteddy]
#1069341
02/22/14 01:54 AM
I agree Eddy. I will pull it out and look at the two that looked original. The fusible links I have seen are as you describe but the wires are not exposed where you can touch them. The inside of that box did not look like it had room for the fusible links I have seen in the past and the white wires looked thick enough that they could handle a hell of a current before melting.
These are just jumper wires with a coating around them like regular wire IMO. They must have replaced the fusible links with jumper wires. lol... Rube Goldberg fix I guess.
I will also thumb thru the manual and see if I can find that box and what the links inside are supposed to actually look like for that application.
Most links I have seen are inside a plastic housing and you twist it and pull it apart and find a fuse. They look nothing like the fuses in a fuse panel.
Matt Hamer 89 Mighty Max SPX Macro Cab 2.6L 5 speed 4X4 Auto hubs.
Re: MM horn Inop
[Re: Hamer]
#1069342
02/22/14 08:56 PM
The ones I've seen have a woven insulation instead of solid plastic, I assume so you can see if they are blown. Not bare wires...
You can check for a voltage drop across the link with a voltmeter. Put one probe on the in, and one on the out and read the voltage.
Re: MM horn Inop
[Re: fasteddy]
#1069343
02/22/14 11:14 PM
Ahhh now I know what your talking about.
I will test the wires and see if there is an issue there. I will check into it more and see if I can locate a picture of what its actually supposed to look like in that box. If they are supposed to look like what you described then they are wayyyyy off. lol.
Thanks for the help eddy
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6007 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-07 06:31:32 UTCValid HTML 5 and Valid CSS
