dyno guess's? #1070159 03/21/14 02:08 AM
powerRam50 Offline OP
putting the d50 on the chassi dyno tomorrow just for fun.wont cost me anything doing it at school. a little back ground it 245000 very hard miles,clearwater head,thorely header,Weber carb,4.6 gears with 35's, and i am at 7200 feet above sea level right now.whats your guess's for hp and tq?
Re: dyno guess's? [Re: powerRam50] #1070160 03/21/14 02:51 AM
60hp/75ftlbs
Re: dyno guess's? [Re: TOASTY] #1070161 03/21/14 03:52 AM
What kind of dyno? Inertial or brake? Will it use SAE correction? Will it adjust to sea level conditions? My guess is about the same if no corrections and an inertial dyno.
Now onto the soapbox. Dyno numbers are just guesses. Too many vairiables to treat them as any better than an educated guess. If you want better numbers, do about 5 quarter mile runs, weight the truck on certified scales, and apply the formula. Much more accurate than a dyno. The formula uses trap speed, not e.t., so reaction times are not considered, so that error source is out the window.
Re: dyno guess's? [Re: fasteddy] #1070162 03/21/14 05:27 AM
1/4 mile time with an NA 2.6? Solitaire goes faster. <img src="/forums/images/graemlins/lol.gif" alt="" />
75 hp / 90 tq
Re: dyno guess's? [Re: rxinhed] #1070163 03/21/14 07:29 AM
Kevin C Offline
71 HP, 89 ft lbs smile
Re: dyno guess's? [Re: Kevin C] #1070164 03/21/14 09:02 AM
Kevin, old friend! Long time no post! How have you been?
And Russel, it's not the 1/4 mile et that takes forever, or even matters. It's the trap speed that's important. I've used trap speed for years to calculate hp, and assess if what I just did to the vehicle did any good. For years I used the same stretch of road, 1/4 mile measured with a steel surveyors tape. Couldn't control ambient temp or weather, but if you could do the runs close in time, it was quite accurate. Of course, like a chsssis dyno, it measured rwhp, not crankshaft hp, but rwhp is real world hp, anyway.
The formula is"
HP = (mph/230)^3 x lbs weight
If your 1/4 trap speed is 75 and your weight when run is 3400lbs, the answer is 117.9hp at the rear wheels, if I did the math right on the back of the envelope.
Re: dyno guess's? [Re: fasteddy] #1070165 03/21/14 01:10 PM
it does not account for the elivation but i do have a caculater app on my phone that will.i am hoping for at least 50 at the rear wheels.elevation alone will drop me from 109 stock to about 85 at the flywheel then all the losses from tranny rear end ext....
Re: dyno guess's? [Re: fasteddy] #1070166 03/21/14 01:11 PM
fast eddy,inertial and i dont believe any corrections..
Re: dyno guess's? [Re: fasteddy] #1070167 03/21/14 04:20 PM
And Russell, it's not the 1/4 mile et that...matters.
FE, ah huh. If he's going to race Monturbo... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: dyno guess's? [Re: rxinhed] #1070168 03/21/14 07:19 PM
41hp at 7280 feet. at sea level about 50hp. 1/4 mile was 25.47 first run and 25.8 second run.did not get a good tq reading..
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6398 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-10-24 03:22:27 UTC
