'94 Montero #1070288 03/26/14 05:00 PM
A
age67 Offline OP
Can buy a '94 Montero with 175,000 for 1800.00. looks super good, but owner is in process of replacing belt tensioner, cam position sensor and crank position sensor.
I need a vehichle for my grandson to ride to school and work, would this be a viable option for him? Any thoughts appreciated.
Eddie
'88 Dodge Raider 2.6L, 5 spd.
Re: '94 Montero [Re: age67] #1070289 03/26/14 07:37 PM
BottomFeeder Offline
If the month runs correctly, I think it would be a good purchase. Was the timing belt changed as well?
Rch
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: '94 Montero [Re: BottomFeeder] #1070290 03/26/14 08:33 PM
geocrasher Offline
Yeah, you don't want a week motor! badump-*tish*
http://tidbitsfortechs.com/
Re: '94 Montero [Re: geocrasher] #1070291 03/27/14 01:03 AM
Damn auto correct... Month = Montero <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: '94 Montero [Re: age67] #1070292 03/27/14 01:19 AM
Talk about doing half a job. If the owner is in there replacing timing-related parts, and I mean ANY of them, he should be replacing everything: cam and crank seals, water pump, timing belt, tensioner and idler. I wonder why the sensors are being replaced?
Other than that, yes, that would be a good vehicle for him to drive. Quite safe.
Re: '94 Montero [Re: JohnnyBfromPeoria] #1070293 03/27/14 03:03 AM
I would want two things done prior to purchase. Pass emissions and a cylinder leak down test, in addition to a clean test drive, of course.
Re: '94 Montero [Re: JohnnyBfromPeoria] #1070294 03/27/14 11:43 AM
A
age67 Offline OP
The reason for doing the work was an issue with dying, it would die, but start right back up, had it scanned at dealer and showed cam position and crank position sensors, one or both bad, after teardown found the belt tensioner bad. will talk to him and ask that he replace the belt also.
Thanks for your help.
Eddie
PS: will give the '88 Raider to another grandson.
Re: '94 Montero [Re: age67] #1070295 03/27/14 11:43 PM
A
age67 Offline OP
Talked to the owner of the Montero, he will install new water pump belt, etc, for just cost of parts, so I will buy it for my grandson. Thanks for all the suggestions.
Eddie
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6258 MB (Peak: 0.7089 MB) Data Comp: Off Server Time: 2026-06-07 09:08:36 UTC
