Gen2 Trailing arm swap... bushings?
#1070317
03/27/14 06:43 PM
Looked but still unsure... Are the axle bushings the same gen 1 to gen 2? Is it just the front body's that are different?
Re: Gen2 Trailing arm swap... bushings?
[Re: Schony]
#1070318
03/27/14 09:11 PM
Yes, IIRC they should be the same. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1070319
03/28/14 05:05 AM
Gen 1 bushings for the fronts.
[Re: Oso]
#1070320
03/28/14 02:23 PM
Cool thanks guy's what I was thinking... rears the same fronts different. I read that the gen 2 front's where flat and the gen 1's rounded. Just wanted to be sure.
[Re: Schony]
#1070321
02/20/15 08:42 AM
Bring an old thread back to life. Im about to do this swapand was wondering about the bushings. I have to use gen 1 ones in the front right? Also there two a side correct? I can use gen two for both of the rears right? So ill be ordering a total of 8 bushings? Also if anyone who has done has part numbers of what wprked that would be awesome. Thanks in advance
1990 5sp lwb 274,000 miles 80,000 on new motor
[Re: 1morebike]
#1070322
02/24/15 12:03 AM
Hmmm not sure about the bushings.
If those are the original bushings, it may be worthwhile to just buy a new set of front ones (2 each side) from the dealer or replace the original ones with the correct sized polyurethane bushings.
As for the rears, I never replaced mine as IIRC they're pressed in and did not require replacing. HTH.
[Re: off-roader]
#1070323
02/24/15 10:38 PM
The rear trailing arm bushings on Gen1 (-91) are the same as "early" Gen2 (92+). However sometime around 1997 they changed the bushing to a simpler single-step looking bushing. Also the trialing arms appear a little skinnier by just a few millimeters.
You can confirm this by looking up the parts at a Mitsubishi parts website or Parts.com or even ASA.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6192 MB (Peak: 0.6935 MB) Data Comp: Off Server Time: 2026-06-07 05:58:25 UTCValid HTML 5 and Valid CSS
