Page 1 of 3 1 2 3
95 montero 3.0 24v Transmission starts off in safe/limp mode #1070597 04/05/14 02:54 AM
rskvjk Offline OP
Almost every time I start the vehicle the first time of the day. It will only do about 20mph no matter how long i let it warm up or even taking it around the block. However, if I turn the engine off and restart it the transmission will let me go between 30-40 then slowly increase the further I travel. What is causing it to start off in limp mode every morning or if I haven't driven it within the last 2 hours?
95 Montero 3.0 24v Newly Rebuilt; Automatic- work in progress
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: rskvjk] #1070598 04/05/14 02:40 PM
Huh? How do you know it's the transmission that's not "letting" you go faster than 20? Do you just leave it in drive? Can you manually shift it, starting in 1st?
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: JohnnyBfromPeoria] #1070599 04/05/14 04:14 PM
rskvjk Offline OP
Its an automatic. I assume that is what it doing after looking up the symptoms online and speaking with a Mitsubishi mechanic about it when I took my newly rebuild engine in to be fine tuned. However, I can't say for 100% because I have no past experience with this kind of issue.
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: JohnnyBfromPeoria] #1070600 04/05/14 05:16 PM
And so I reiterate:
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: JohnnyBfromPeoria] #1070601 04/05/14 05:24 PM
rskvjk Offline OP
Oh sorry, thought you were asking if it was a manual or automatic.
Yes, I always use Drive- never used the lower gears but I can try when I go out later today.
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: rskvjk] #1070602 04/06/14 06:10 AM
MBrannon Offline
Auto limp mode puts it in a higher gear all of the time. 3rd I think, maybe second. It won't have any balls from a stop, but you can easily go more than 20 or 30. 55+ is no problem in limp mode. You have a different issue.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: MBrannon] #1070603 04/06/14 08:44 AM
rskvjk Offline OP
UM, that makes no sense. Limp Mode is suppose to limit your vehicle so you can make it safely home, off the road, or nearest repair shop at a very slow speed so you don't damage your vehicle. Doing 40 to 55 mph is normal speed.
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: rskvjk] #1070604 04/06/14 09:26 PM
rskvjk Offline OP
OK, I changed the aft yesterday because my husband mentioned he used a multipurpose aft from Atwoods when he changed it 2 wks ago- it said it was dextron II but who knows. So I put Valvoline MaxLife Dex/Merc in it- Jez that the stuff stinks to high heaven.
Took it out for a drive the is morning, started- stalled, started-stalled ( can't wait for the new IAC to come in) - after throttling up to get her to increase the fuel so she'd run- I took her thru L-2-D like you asked. Still had a hard time shifting until it warmed up more and then smoothed out.
I did find a atf leak- small leak coming out the weep hole between the transmission and transfer case. I am so not looking forward to repairing those 2 seals(mainly because the Maxlife STINKS SO BAD). Thought I might try AT-205 reseal first.
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: rskvjk] #1070605 04/07/14 12:49 AM
Djunk Offline
When I bought my 94 SR the people before me had been trying to troubleshoot it for a while cause it was in Limp mode. I found that the Crank bolt had loosened and the crank sensor wheel had broken free of its locating pins which I think put it in limp mode. If your Monty is indeed in Limp mode might want to check some of your sensors.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: 95 montero 3.0 24v Transmission starts off in safe/limp mode [Re: Djunk] #1070606 04/07/14 01:14 AM
rskvjk Offline OP
I remember the crank bolt being a pain to keep torqued correctly when I was setting the timing while i was putting the engine back together after a complete strip down. Had to replace the rings, pistons, & wrist pins.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6388 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-11-03 13:39:35 UTC
