Evoscan?? #1070637 04/07/14 04:47 AM
rskvjk Offline OP
Will Evoscan work on 95 Montero LS 3.0 24v?
95 Montero 3.0 24v Newly Rebuilt; Automatic- work in progress
Re: Evoscan?? [Re: rskvjk] #1070638 04/07/14 01:05 PM
Don't know the exact answer, but since the 95 isn't ODBII, wouldn't that imply a "no" answer? I know from past talks with OldColt that later Montero ECUs can be accessed, like my 00 for example.
Re: Evoscan?? [Re: MontyMcV] #1070639 04/07/14 03:39 PM
DR1665 Offline
I suspect, if you can re-pin the harness (or make an adapter from an old harness/ECU) and re-sensor where existing sensors will not suit the expected input ranges, you could run an Evo ECU in anything...
Brian DR1665 | GBXM | Gearheads United.
89 Raider SWB [rock] | 91 Galant VR4 [roller]
Re: Evoscan?? [Re: DR1665] #1070640 04/07/14 05:06 PM
I am not familiar with what EvoScan does specifically. As for later Mitsu ECUs, Charlie has software to tune them. I beleive it is Mitsu software, but am not sure. Making us of this would of course remove the need to wire up an aftermarket FMS. Our discussions on this were more about optizing for fuel efficiency than upping HP. Nominal gains in HP would be welcome, but thought there was room for much inprovement in MPGs.
I am hoping to explore this futher with him this year when we do the MT swap into the 00...
Re: Evoscan?? [Re: MontyMcV] #1070641 04/07/14 07:36 PM
Canyonero Offline
From what I've read on the subject, '95 is referred to as a "hybrid" system as far as OBD is concerned. Hybrid meaning a OBD I ECU, with an OBD II plug for the harness. I'm not familiar with EvoScan so I don't know if it works with Mitsus with this hybrid system or not. I was going to try this system (middle of the page) but I have not contacted the site owner to see if their software and interface will work with the Montero.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Evoscan?? [Re: Canyonero] #1070642 04/07/14 08:26 PM
rskvjk Offline OP
EvoScan runs MutII - at least according to the <a href="websitehttp://www.evoscan.com/evoscan-gps-obdii-cables/details/15/1/performance-vehicle-pc-diagnostic-interfaces/evoscan-13u-universal-usb-datalogging-and-reflashing-cable" target="_blank">websitehttp://www.evoscan.com/evoscan-gps-obdii-cables/details/15/1/performance-vehicle-pc-diagnostic-interfaces/evoscan-13u-universal-usb-datalogging-and-reflashing-cable</a>
I'm not interested in flashing or fine tuning. I just want something that I can read the data with like fuel trims, sensors, IAC steps, etc
Re: Evoscan?? [Re: rskvjk] #1070643 04/07/14 09:59 PM
P
pcc Offline
EvoScan runs MutII
Frank was selling a MutII (or MutI) can't remenber.
Re: Evoscan?? [Re: pcc] #1070644 04/07/14 11:57 PM
rskvjk Offline OP
In the private garage sale? He listed a Mut-1.
Re: Evoscan?? [Re: rskvjk] #1070645 04/08/14 01:39 AM
PHIL_ Offline
I ran EVO-scan on my 96 JDM Evo IV. It was great for pinpointing an ABS fault, and resetting the code after I had fixed the problem. Otherwise, not a huge amount of info from that particular ECU, but as the years went on, I heard more info was sent to the OBD port...
Re: Evoscan?? [Re: PHIL_] #1070646 04/08/14 02:54 AM
Move to Az and i'll let you use my MUT-II, today i used it to set my new TPS. Man that was easy.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6371 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-11-03 13:38:15 UTC
