aftermarket fuel injectors for 1989 3.0L and cleaning induction #1070856 04/14/14 10:32 PM
L
losduarte Offline OP
Is there any difference between aftermarket and original fuel injectors for the 1989 V6? Some places want up to $100 for 1 new Nikki or $300 for 1 new Denso injector.
How should the induction system after the throttle body be cleaned?
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: losduarte] #1070857 04/14/14 11:08 PM
Why do you need a new one? Have you had the old ones cleaned and flow/leak tested? It's fairly cheap compared to replacement, and then you know if you really need to replace one. Google Cruzin Performance...
To clean the intake, make sure you block the port (about .5" in diameter in the bottom rear of the throttle body bore) for the icm bypass, as the cleaning agent eats out the insulation in the icm stepper motor and causes shorts, icm failure, and likely a burnt up ecu, all serious. To be really safe, remove the TB completely and clean it by wiping with a solvent dampended rag, then spray the rest with TB cleaner.
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: fasteddy] #1070858 04/15/14 07:59 AM
L
I was thinking that I should buy some injectors as I'm afeared that sooner or later they will become an obsolete part and then I'll really be in deep doo doo.
Thanks for the suggestion on cleaning the induction system. After taking my engine apart for the rebuild one look inside was yikes...coal tar!
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: losduarte] #1070859 04/16/14 12:55 AM
KrzyDav Offline
I've got injectors I pulled from junkyards. Couple bucks. If I ever need to change one I've got a few to have done by cruisin and I'm set. They all check ohm ok. My truck has all it's original with 260,000 on them and 25 years.
dave h.
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: KrzyDav] #1070860 04/18/14 12:38 AM
L
I wish I had access to that here. We're talkin' bucks from the Mitsubishi Junkyard in Sacramento.
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: losduarte] #1070861 04/18/14 01:13 AM
Oso Offline
91 at the newark picknpull.
91 at the fairfield location
89 at the san jose north yard.
i'll tag along if you want to go. i've got a morning free this weekend.
Re: aftermarket fuel injectors for 1989 3.0L and cleaning induction [Re: losduarte] #1070862 04/19/14 12:47 AM
KrzyDav Offline
I used to live in Sac. I never bought anything from Mitsu/Saturn yard in Rancho. The one part I almost bought was 3 time the price as I paid at the dealer for a new one.
All Japanese on one of the culdesacs in Rancho was always fair and let me have the run of the yard.
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6234 MB (Peak: 0.7146 MB) Data Comp: Off Server Time: 2026-05-29 18:53:45 UTC
