Gen 1 Auto Tranny issues #1070873 04/15/14 01:48 AM
RECON45 Offline OP
In the past couple of days the little 3.0 raider has been having auto tranny issues. it started out reving close to 4k rpms before shifting to overdrive. now it does not go into overdrive and does not want to go into 3rd gear unless it gets well over 4k rpms and the needle is bouncing. No leaks plenty of fluid. No sounds to allude to anything going on. i did smell something but could not put my finger on what the smell was. Any advice or help. just curious if my 91 lwb tranny will swap in with no worries. i think so but wanted to make sure.
Re: Gen 1 Auto Tranny issues [Re: RECON45] #1070874 04/15/14 03:58 AM
silveraider Offline
Check the throttle cable tension for the trans. There is a wrote up on how to do it in the archives. I adjusted mine to actually have it kick in a little later as she was shifting way too soon.
Re: Gen 1 Auto Tranny issues [Re: silveraider] #1070875 04/15/14 04:38 AM
RECON45 Offline OP
If thats the case what would cause it to suddenly happen?
Re: Gen 1 Auto Tranny issues [Re: RECON45] #1070876 04/15/14 04:39 AM
Kevin C Offline
Also check to see if the cable is sticking. The liner can get gunked up over time.
Re: Gen 1 Auto Tranny issues [Re: Kevin C] #1070877 04/15/14 04:55 AM
Oso Offline
had to replace mine. got some great advice and posted pics. not too tough. if you have to go that way: throttle cable
Re: Gen 1 Auto Tranny issues [Re: Oso] #1070878 04/15/14 10:32 PM
RECON45 Offline OP
I took a look and the cable on the throttle body is pulled out and does not retract. So i will start with that. do you have the part number, exact part name. is it easy find? expensive? Thanks
Re: Gen 1 Auto Tranny issues [Re: RECON45] #1070879 04/16/14 12:50 AM
It's called the throttle valve cable, or TV cable. I can't find the part in ASA...
Re: Gen 1 Auto Tranny issues [Re: fasteddy] #1070880 04/16/14 03:57 AM
RECON45 Offline OP
thats what I thought but wanted to make sure it was nothing special mitsubishi name. I need to see if the zone or napa has something. Thanks
Re: Gen 1 Auto Tranny issues [Re: RECON45] #1070881 04/16/14 08:26 PM
Oso Offline
had to visit the stealer for mine. $100.... let us know what you find.
Re: Gen 1 Auto Tranny issues [Re: fasteddy] #1070882 04/17/14 01:51 AM
I couldn't find it in ASA either, last time I looked. Also, Rock Auto does not list one for the application I was looking for.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6418 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-06-07 05:59:10 UTC
