I think motor gave out finally... Motor options #1070901 04/15/14 03:41 PM
Angelo Offline OP
I'll know more this weekend but it made a sound that I've never heard before. Sounded like a belt at first & but was losing power. As I was pulling over, it was ticking pretty hard & cut off on me. Couldn't turn her back over. But I'll know more this weekend when we get into it.
Just wanted to plan ahead. I have a few options. I have a junked Montero stored away with 180k miles on it but the motor had seals replaced right before it was wrecked.
Do I take That motor and swap it in and drive till that one goes, rebuild that motor with new parts or look into a Pajerp turbo diesel motor swap?
I would obviously live the turbo diesel but if it will take a lot of work to function properly, I'll go a different route. Wanted to hear options first
Re: I think motor gave out finally... Motor options [Re: Angelo] #1070902 04/15/14 07:29 PM
If you don't have emissions where you live the diesel swap is easy, the hard part is that your truck is OBD-2 and without that functionality you won't pass emissions.
Obviously swapping another 3.5 SOHC is the easiest route.
Re: I think motor gave out finally... Motor options [Re: TOASTY] #1070903 04/15/14 09:15 PM
Angelo Offline OP
Looks like that will be the route I go. A lot involved in swapping a diesel, tho it would be badass. This guy did it
Montero diesel swap
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5968 MB (Peak: 0.6507 MB) Data Comp: Off Server Time: 2026-05-29 23:53:46 UTC
