I'm picking up another SR for cheap! #1070926 04/16/14 03:15 PM
Djunk Offline OP
SO turns out another SR is falling into my lap and I just cant pass it up. It's a 96 with around 150,000 on it. The motor is siezed or something don't know for sure but for the price ($600) I dont care much. My 94 is a bit rougher than the 96 but does have a functioning engine. So looks like I'll be swapping the engines and I'll have to swap the BL over to the 96. I'm pretty excited about all the possibilities. One question I have is about doing the swap. Previously I pulled just the engine on the 94 and it was a bit of a pain getting to all the bell housing bolts. Does anybody have any recomendations on pulling the engine/tranny/transfercase as one unit? is it possible. There's not a whole lot of space in the engine compartment and I haven't done this before. Any comments would be appreciated. Thanks.
PS I'm a newb but I aint scared to get after it.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: I'm picking up another SR for cheap! [Re: Djunk] #1070927 04/16/14 11:24 PM
Jay Ayala Offline
doesn't the drive train typically get installed as a unit from the factory?
Re: I'm picking up another SR for cheap! [Re: Djunk] #1070928 04/17/14 01:43 AM
I wouldn't suggest trying it. Why not undo the bellhousing bolts on the '94, then remove the body lift, install the body lift on the '96 and install the engine. The body lift should make it quite a bit easier to get at the bolts.
They may have installed the power train as a unit at the factory, but it doesn't mean you have the same access, as other things installed are going to be in the way.
If you use the engine from the '94, you are not going to get the OBD-II diagnostics that are in the '96. You'll also need to swap the engine ECU and probably its harness.
Re: I'm picking up another SR for cheap! [Re: JohnnyBfromPeoria] #1070929 04/17/14 05:29 AM
justice Offline
Why would the OBD 2 not work in the 96 if you swapped in an engine from a 94? will all the sensors not swap over? Im thinking he plans to swap long blocks and keep engine management stuff in place...
Re: I'm picking up another SR for cheap! [Re: JohnnyBfromPeoria] #1070930 04/17/14 04:03 PM
We put a '94 Motor into Lloyds '96, we just swapped the '96 sensors and intake over onto the '94. For the most part even the sensors are the same except one or two on the intake.
Re: I'm picking up another SR for cheap! [Re: TOASTY] #1070931 04/17/14 09:42 PM
Not from a gen2, but I've installed the engine, tranny, and tcase as a unit. It would be easier to install engine and tranny, then put the tcase on from the bottom. It's quite hard to tilt the motor correctly with all that weight on the tail end just hanging..
In any case, if you drop the tcase xmemeber, the motor tilts aft far enough to get at the upper BH bolts with enough wobble extensions.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6146 MB (Peak: 0.6852 MB) Data Comp: Off Server Time: 2026-07-16 03:41:53 UTC
