2002 Sportage engine shot #1070943 04/17/14 11:25 PM
V
Vigbert Offline OP
Overheated, up to the H. I pulled over and it stalled and wouldn't restart. I smelled coolant.
I had it towed to a Kia dealer who said there was no coolant in the system and compression in #s 2 & 3 is shot.
Dealer says it needs an engine replacement, which will cost ~$2500. So I'm taking suggestions on how to proceed. Doing it myself isn't an option. I will go there tomorrow to find out the itemized charges (labor/engine cost) and if the replacement engine is a rebuilt or just from a boneyard.
Other than that problem, the Sportage is relatively solid and in good shape. I bought it less than a year ago for $2000 w/ 84K on it. It has 90k now. I know sinking $2500 into gives me a vehicle worth less than that, but I'm on a low budget. smile
Thanks for any suggestions.
Re: 2002 Sportage engine shot [Re: Vigbert] #1070944 04/18/14 01:37 AM
Peabody Offline
For $2500, you could buy another Sporty. I think you are better off looking for a bone yard engine. You can also check eBay Motors, but look for a regional seller to keep your freight cost down. There's an outfit in San Francisco that says they sell low-mileage engines pulled from Japanese Sporties. But that might be an expensive freight bill to the east coast. And that's assuming they actually have a Sportage engine. My vote is for the bone yard.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 2002 Sportage engine shot [Re: Peabody] #1070945 04/18/14 01:46 AM
Peabody Offline
Here's the link to the low mileage engine place.
And... they have free domestic shipping in the continental US.
Re: 2002 Sportage engine shot [Re: Peabody] #1070946 04/18/14 01:54 AM
V
Vigbert Offline OP
Thanks, Peabody.
Re: 2002 Sportage engine shot [Re: Vigbert] #1070947 04/18/14 07:27 PM
jaybrian32 Offline
You may also get away with a top end rebuild, new head gasket, cylinder head skimmed and pressure testing should come in around $600-$750 with investigation as to why it over heated in the first place.
Try a reputable independent garage, not a main stealer.
Re: 2002 Sportage engine shot [Re: jaybrian32] #1070948 04/19/14 08:05 AM
Peabody Offline
True. If he's lucky, it was just a few valves failing. If it's the piston rings, then there's a bit more involved. On that note, I was looking into the cost of replacing the cams on my engine and found it was far cheaper to get a rebuilt head complete vs the cost of replacing parts. Whooda thunk it?!? <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: 2002 Sportage engine shot [Re: Peabody] #1070949 04/21/14 10:22 PM
jaybrian32 Offline
Given the symptoms described,I'd say failed viscous fan or thermostat caused it to overheat rather than mechanical failure, blowing the head gasket, causing loss of compression on 2 or more cylinders. Start with basics oil/coolant contamination, and a compression test.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6192 MB (Peak: 0.6941 MB) Data Comp: Off Server Time: 2026-10-21 16:20:15 UTC
