Which Mighty Max transmissions will fit my Raider? and how much do they weigh? #1070981 04/18/14 07:23 AM
geocrasher Offline OP
So I'm still on the prowl for a cheap replacement for my KM-145, and I have been keeping an eye open for Mighty Max's too. I just need the 2.4/2.6 wide block bolt pattern with a hydro clutch, right? The rest should bolt up?
Also I may need to ship. How much should I expect to pay for a tran+tcase strapped to a pallet? I don't know how much these things weigh. I'm thinking <$100? If so I have a line on a rebuilt trans/case for $300+shipping if I can get the guy to ship it to me.
Thanks guys. Trying to keep this pig on the road smile
http://tidbitsfortechs.com/
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: geocrasher] #1070982 04/19/14 12:40 AM
KrzyDav Offline
this probably won't help you find what you need,,,but the USA 97 2.4 Montero Sport had the ?V5mt1? (corect my number if wrong please). I think it is basicly the 145 beefed up a bit. The Montero sport I believe was a hydaulic clutch. UInfortunately the one at my local yard is now melting in China.
dave h.
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: KrzyDav] #1070983 04/20/14 02:52 AM
This sounds pretty cool, I'd love to corroborate it with evidence. Has anyone done this? Is it a bolt-in?
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: geocrasher] #1070984 04/21/14 04:05 AM
PartyTruck Offline
Don't all the Astron engines share the same bellhousing pattern? The older 4D56's can use the later V5MT1 gearboxes so if that fits you could also look out for 4cyl RWD Hyundai's and Kia's if they are available in your region.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: PartyTruck] #1070985 04/21/14 06:15 AM
spencevans Offline
The only Mighty Max transmissions that are compatible with the Raider are the KM145 found in the Turbo Diesel pickups. While Mighty Max pickups share a common bell housing, the KM145 on the diesel pickups, Raider and Montero is a hydraulic actuated. Those found on the Mighty Max are cable actuated. It's not a big deal but I would recommend finding a transmission from another Raider.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: PartyTruck] #1070986 04/21/14 08:20 PM
LandRaider Offline
My diesel raider has a V5MT1 in it. It is in no way related to a KM145. Major beef. Cast iron... If you can get one it will last. Just keep GL4 in it.
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: KrzyDav] #1070987 04/22/14 12:44 AM
plh Offline
the USA 97 2.4 Montero Sport had the ?V5MT1? (corect my number if wrong please).
If I'm not mistaken, the Sports with the 2.4L were only 2 wheel drive, but if they do have the V5MT1 transmissions, this could be a source for a detachable bellhousing in which case the V6 Montero (not sport) 5 speeds which are V5MT1 would be a fab-up possibility. Would need the T-Case also, probably custom drive shafts...
The KM145 without t-case weighs right around 100 pounds packaged for shipping. I've sent a few.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Which Mighty Max transmissions will fit my Raider? and how much do they weigh? [Re: plh] #1070988 04/22/14 02:42 AM
These are all fascinating ideas, thanks for them. Can you expound on what method you shipped and how much it usually cost you? Might be my best bet for getting another KM145 as they are scarce around here.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6244 MB (Peak: 0.7249 MB) Data Comp: Off Server Time: 2026-05-29 21:12:45 UTC
