Page 3 of 3 1 2 3
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: LandRaider] #1071169 07/04/14 02:27 PM
Pete_D Offline
I run a 91 (92 here) with retro fitted 2.8 TDI...the stock gears like yours have been working out well...I'm not sure under wheeling conditions I would want less.....my big need at the moment is a kickdown cable.....
The 2.8 retro was done for some special police applications along with a few privately owned vehicles and the cable is not available here...if anyone runs across one let me know....
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: Pete_D] #1071170 07/12/14 07:45 PM
roninguitars Offline OP
I would be curious to know if anyone out there has to say about highway speeds and rpm's using the 4d56T and a 4.66 diff ratio. I have located front and rear 3.9's out of a 4x4 MM truck and the rear is the LSD versionàI was going to wait til the engine is in and I can see how she drives before changing the differentials. I would love to be able to drive at decent highway speeds and get good mileage.
The engine swap takes place next week and I will have bunch of photos.
I am taking out the AC system (no need for it in Humboldt, CA) and putting in a big ol front mount intercooler along with cockpit boost controller and EGT/Boost gauges where the old radio use to be.
The next question is, does my 199k mileage transmission need a rebuild to handle the diesel?
"I'm gonna whittle you into kindling' Black Crow 16 shells from a thirty-ought-six" - Tom Waits
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071171 07/20/14 07:04 PM
haztoys Offline
The place to find 7.5 3.54 gears is in a flaty Starion or the early RWD Dodge/Mitsu cars ...Same gears as in the front of the 4 cyl montys and trucks...To bad I just recycled some ...No clue anyone would want them ...
I would reman the trans at 199k the oil burner motor would be to hard on the small trans
Captain Gear Box
Hazardous Toys inc
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: haztoys] #1071172 08/05/14 04:53 AM
I've got an LSD 3.90 rear and standard front from a MM ready to go in so that should allow for 60-65 mph and great MPG. Syncro/bearings/seals all getting redone on the tranny.
Very excited to see what this big front mount intercooler does for the power...
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071173 12/25/14 07:57 PM
Happy Holidays to everyone out there! I just got the 4d56 into the engine bay after rebuilding the transmission and adding in the 3.54 gears into both diffs. I took the rear diff from a MM and the rear diff from a Starion (used just the ring and pinion) and everything fit great. The air conditioning is coming out for a big front mount intercooler. I will post pictures and videos in January.
Looks like I will be going with this intercooler from a company in Australia.
450 x 300 x 76 intercooler core
If anyone has had experience upgrading the turbo on the 4d56 id like to know your experience. I read on another forum that this was a good upgrade.
Kinugawa Turbocharger 4D56T 2.5L Pajero Upgrade TD04-13T 5 bolt Oil & Water-cool
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071174 02/19/15 11:31 PM
Some progress here...intercooler mounted along with the water/fuel separator. Still figuring out the wiring for the tach and glow plug to mate up with the mk1 diesel cluster from the UK. The K&N Apolo intake is next along with the 2.5" exhaust. She started right up and rev'd smooth with no black smoke!
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071175 05/30/15 02:09 AM
JeffatTireBalls Offline
How much better does it run with the intercooler?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: JeffatTireBalls] #1071176 06/02/15 01:55 AM
red1987raider Offline
Nice to hear from you again. Hey, I haven't put the intercooler in yet because I'm still trying to locate one that will fit. But I'm running the rig without it and no problems so far. Mileage isn't that much better than the gasser, though. I'm hoping the intercooler will change that.
1987 Dodge Raider converted to 4D56T
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: red1987raider] #1071177 06/05/15 02:08 AM
lordtrunks Offline
I get 24-26 mpg with extremely heavy 37's loaded or unloaded you should be getting about the same. My 12V v6 only got 10 mpg with the 37s and even less when loaded.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: lordtrunks] #1071178 06/05/15 05:23 AM
My mpg with 4D55 in my old '88 2 door automatic was about 25mpg on 31" tires and about the same on 33's but with less power. Far better than any 4G54 (2.6L) I ever owned, milage never made up for what I spent on the setup but the cool factor was way there and so was the power. BOOOOST!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
My 6G74 (3.5L) gets 15-18mpg on 35's in my gen 2, I don't think fuel economy and Montero go together at all. Montero's are just plain fun and that's the price of admission (as our resident Bullworker would say).
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 17 (0.006s) Memory: 0.6453 MB (Peak: 0.7834 MB) Data Comp: Off Server Time: 2026-07-09 16:46:28 UTC
