Page 1 of 3 1 2 3
Gen1 5.3 swap thread. #1071288 04/28/14 04:04 AM
StockRaider Offline OP
Ive begun more work on my 5.3 swap and decided I would create a new thread to avoid having people getting lost in pages of rambling. After I finish, I plan on doing a write up with part numbers and years I used for everything.
Basically pictures of stripping the engine bay down today.
Old pictures
Last two days progress, removed the trans, the exhaust, all fuel lines, heat shields, and everything else in the engine bay I felt needed to be ousted for the respray after I cut the firewall.
Last night I wanted to test fit to see where and what needs cut, and the trans tunnel needs to get cut by 2-3 inches wider for a few inches. Also doing a body lift here soon, so will cut after thats installed.
Also, I decided on the NP205 transfer case from a 78 Bronco would be my choice for the project. Strong, gear driven, and plentiful. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071289 04/28/14 05:12 AM
Too bad all the pics are gone from the thread that 777 had so many years ago. He also redid the trans tunnel, but for the NV4500. Lots to move around. Are your measurements indicating relocation of heater core and other things inside?
777 thread for 6.0L
Re: Gen1 5.3 swap thread. [Re: rxinhed] #1071290 04/28/14 05:30 AM
The body lift should prevent too much hacking of the trans tunnel. I plan to make some minor and major changes along the way. The 5.3 is 300 hp, and the np205 will be twin sticked for sure so it will be an original build. I am ordering a body lift and a can of POR and a few rolls of thermotec suppressor mat. <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071291 04/28/14 05:48 PM
Devilmontero Offline
Keep us posted with plenty of pictures and details. I'm very interested in this. I've been contemplating a 5.0L swap from an Explorer. If this isn't too bad I may lean towards this direction.
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
Re: Gen1 5.3 swap thread. [Re: Devilmontero] #1071292 04/28/14 06:47 PM
If I had been doing this In the 4 door I would use a shorter 2wd manual trans and a divorced transfer case and avoid the extra 1k in adapters. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071293 04/29/14 04:35 AM
Why the Ford part instead of an NP231 or NV241?
Re: Gen1 5.3 swap thread. [Re: rxinhed] #1071294 04/29/14 05:01 AM
The ford np205 has a drivers side drop, is gear driven (no chains to stretch or break), and costs $100 each at local yards. So even if I somehow broke the cast iron case, I can just go buy another one pretty easily. Also, they come fixed yoke front and rears so no slip yoke eliminator kits like with the other mentioned cases. I just get my custom shafts made and am in business. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Also, the np205 has the ability to be twin sticked.
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071295 04/29/14 02:50 PM
lordtrunks Offline
I remembered this video this morning figured i'd share this is a 5.7 but i hope yours comes out just as mean
http://www.youtube.com/watch?v=82qKhlku0qA
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Gen1 5.3 swap thread. [Re: lordtrunks] #1071296 04/30/14 02:40 AM
Ive seen that video before, I plan on keeping my Raider a very on road creature. More like a steroided up Raider. I plan to chop the 4 body mounts under the doors and raising them to match the front and rear body lift blocks, and then run the exhaust outside the frame, and build rock sliders to protect it from damage, exiting before the rear tires. I hope it sounds nice and not annoyingly loud, but we will see...
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071297 04/30/14 01:44 PM
lordtrunks Offline
There are enough different types of mufflers out nowadays you should have no problem finding one that will keep that v8 quiet.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6437 MB (Peak: 0.7699 MB) Data Comp: Off Server Time: 2026-07-13 11:49:33 UTC
