Page 2 of 3 1 2 3
Re: Gen1 5.3 swap thread. [Re: lordtrunks] #1071298 04/30/14 07:01 PM
Trust me on this. You must have a xover pipe between the banks, or it will sound like a 4cyl oddfire when it passes.
Also gets some flow improvement and really evens out the sound into a good rumble instead of a raspy sound. This is not an issue with rear exit duals, but it is in side dumps.
There's lots of room for the exh at the sides where you can armor it up well. I'd joint the exh at the places where it goes straight down the sides to make it easier to remove with the rock bars in place. Ever think about making the rock bars the exhaust pipes?
Re: Gen1 5.3 swap thread. [Re: fasteddy] #1071299 05/01/14 03:20 PM
monte3 Offline
Rock bars as exhaust pipes = <img src="/forums/images/graemlins/evil.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Gen1 5.3 swap thread. [Re: monte3] #1071300 05/01/14 04:46 PM
87Montero Offline
Like this??
https://www.youtube.com/watch?v=RROCyWhGRlc
Re: Gen1 5.3 swap thread. [Re: 87Montero] #1071301 05/16/14 04:17 AM
StockRaider Offline OP
Small update:
I was stripping the old fuel lines brake lines and removing old mounts and things got kinda out of hand...
only 1 bad body mount, but its BAD...
I will get back to the engine swap after I finish POR15 coating the frame, repairing the rust holes in the body, and installing a 3 inch body lift. Lots to do, but all I have is time (and welder).
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071302 05/16/14 11:44 PM
PartyTruck Offline
Have you thought about raising the fuel tank up with the body, that would clear it of rocks and stuff, also eliminates the need to modify the filler tube and breather.
Easy thing to do with the body out of the way since it would just need mounts on top of the cross-pipes it's hanging from today.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Gen1 5.3 swap thread. [Re: PartyTruck] #1071303 05/17/14 02:58 AM
I have some NICE rust-free frames you need.
Re: Gen1 5.3 swap thread. [Re: rxinhed] #1071304 05/17/14 07:17 PM
I would love to buy a clean 4 door. My montero is a lost cause sadly. I wish I could find a clean one with a moon roof. Raiders frame is pretty legit other than the one small spot I broke open with a hammer while "pinging" the frame.
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: PartyTruck] #1071305 05/17/14 08:16 PM
My fuel tank is rotted on top, so I am going to go fuel cell and try to raise it up the 3 inches.
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071306 07/21/14 04:07 AM
*Small Update*
I finished most of the work on the frame, and reattached the body. I really like how the body lift gave the 33s a more factory look. Test fitting has restarted on the 5.3, and after cutting the floor out slightly, it has made the fitting a far easier task. I have to buy a lower profile oil pan from a Vette, and block hugger manfolds, but it's coming around. Just gotta wait for some more $$ <img src="/forums/images/graemlins/lol.gif" alt="" />
Ohyea, Pics!
before installing body blocks
removing old unneeded accessory mounts with weld cutter
Cutting required space from the floors.
First "real" test fit! That looks so freaking awesome!
More to come as my money allows. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Gen1 5.3 swap thread. [Re: StockRaider] #1071307 07/21/14 05:03 AM
LandRaider Offline
Looking good.
I'm surprised by the lack of cutting to make it fit good.
How's the clearance up front at the accessories?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6481 MB (Peak: 0.7769 MB) Data Comp: Off Server Time: 2026-10-22 00:09:53 UTC
