most common parts failure gen 1 v6 #1071654 05/12/14 06:06 AM
1
1morebike Offline OP
i'm wondering what spare parts to carry i worry to much about being stranded and would like to have parts and the know how to save myself from a long walk. so whats a must carry ?
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: most common parts failure gen 1 v6 [Re: 1morebike] #1071655 05/12/14 10:01 PM
Every possible hose, belts, a decent amount of every fluid the truck requires, a few tire plug kits and an air compressor.
And make sure the engine has the most recent crank bolt in it.
Re: most common parts failure gen 1 v6 [Re: JohnnyBfromPeoria] #1071656 05/13/14 05:11 AM
Oso Offline
i read this and decided it would be a good idea to double check my spares kit before i do this run in a few weeks. and I dont like the prospect of walking either. somehow, somewhere, I lost my spare belts kit. <img src="/forums/images/graemlins/scared.gif" alt="" />
the belt store (yep there is a tienda here that just deals with rubber) carries gates and goodyear - which is great! but cant look anything up by vehicle - just sizes - which is not great.
FWIW the rest of my kit (besides tools):
ecu x2
starter x2
coil/power unit
tie rod ends
cap & rotor
thermostat
radiator cap
battery cable (6 ft)
electrical kit
radiator hoses
gorilla tape
fluids - all of them
oil, fuel, & air filters
belt kit (soon) <img src="/forums/images/graemlins/zombie.gif" alt="" />
2 spare tires
extra tp
other small odds and ends....
pb blaster, starting fluid, gojo,
HF 150-psi air compressor & tire plugs
tent, sleeping bag, butane stove
spare water & fuel
chewing gum
paper manuals (currently with johnnyb)
Re: most common parts failure gen 1 v6 [Re: Oso] #1071657 05/14/14 01:53 AM
justice Offline
If you do any tough wheeling, swap out your trailing arms for Gen 2 Arms.
Re: most common parts failure gen 1 v6 [Re: justice] #1071658 05/15/14 01:39 AM
Universal joints
Re: most common parts failure gen 1 v6 [Re: JohnnyBfromPeoria] #1071659 05/18/14 03:21 AM
1
how would i know? the po put in a auto zone motor in like 2009 or something like that.
Re: most common parts failure gen 1 v6 [Re: 1morebike] #1071660 05/18/14 04:46 AM
Oso Offline
This is definitely something you want to check. crank bolt
read all the way to the bottom. The photo at the bottom is the correct one. At least I hope so as it is what i put in my rig last year.
It can be tough to pull. I used a chain wrench and old fan belt. Lots of good ideas on here how to get it out easily.
Re: most common parts failure gen 1 v6 [Re: Oso] #1071661 05/18/14 05:03 PM
Bernoulli Offline
Thanks for the list. I only use my car to go where I want, not to go where no one has gone before, so I doubt I need all that stuff. I do carry the manuals and fluids. At one time or another I've blown every water hose, so I try to replace them regularly and carry the replaced for spares. The heater hoses are not so tough to replace if you have a 1/4" drive ratchet with a flex extension and appropriate socket. I have a tool kit. Most of my dedicated space is filled with recovery gear.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: most common parts failure gen 1 v6 [Re: Bernoulli] #1071662 05/18/14 05:48 PM
Oso Offline
all the stuff on my list isn't really essential. at the moment i'm doing some expedition type stuff. i had all the extras just sitting around from the build so i threw them in the box. the only thing i've had to use so far is a spare coil and power unit. not sure which one went bad - i replaced them both on a hunch and the rig runs great. when i get back to civilization i'll carry my basic tools, AAA card, and a cell phone. other than the lack of horsepower i like my 3.0. overall, the vehicle seems pretty tough.
Re: most common parts failure gen 1 v6 [Re: Oso] #1071663 05/20/14 01:47 AM
Use an air ratchet.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6413 MB (Peak: 0.7665 MB) Data Comp: Off Server Time: 2026-05-29 15:04:09 UTC
