Found a dyno run with turbo swb oh yeah #1071716 05/15/14 03:24 PM
87monty Offline OP
Wanted to share this video, not sure if anyone has seen this yet. 259HP!
Mitsubishi montero turbo dyno: http://youtu.be/Zlj-nUPgjUs
I love turbos, starting my 4G64 transplant....its about time!!!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Found a dyno run with turbo swb oh yeah [Re: 87monty] #1071717 05/15/14 04:38 PM
Never seen a dyno. Looks like it is showing 259HP max. And would that then be at the wheels?
Re: Found a dyno run with turbo swb oh yeah [Re: MontyMcV] #1071718 05/15/14 04:42 PM
87monty Offline OP
Looks like it to me...Pretty good numbers, a puff of smoke could be raw fuel after he let off.
96 SR
Re: Found a dyno run with turbo swb oh yeah [Re: 87monty] #1071719 05/16/14 06:25 PM
MBrannon Offline
Yes, that is wheel horsepower.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Found a dyno run with turbo swb oh yeah [Re: MBrannon] #1071720 05/16/14 07:39 PM
87monty Offline OP
Im hoping to get that with my 4G64 Swap,With proper tuning and the turbo im using I may see more.
96 SR
Re: Found a dyno run with turbo swb oh yeah [Re: 87monty] #1071721 05/30/14 01:50 AM
JAVYPRO Offline
LOL, That is from my native Puerto Rico, I was back in the island two years ago and you got to see my friend's turbo 1983 spinning all 4 swampers on the pavement, INSANE, SIMPLY INSANE.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Found a dyno run with turbo swb oh yeah [Re: JAVYPRO] #1071722 05/30/14 03:41 AM
Stock, an 88-89 had 206hp at only 10psi of boost. It doesn't take a lot of tweaking to get 250+ hp. That was with a small 12a turbo. I bet the 14 dealer installed upgrade made 250. That's with a long stroke 2v motor with lousy breating off a simge barrel TBI setup double wye manifold with really crappy distribution.
The 4g64T with a 4v head and much better IR + plenum intake will make nearly 250 at the crank. The original 4G63T made 198 at the crank. With a 16 size turbo for a lot more air, I bet you will have 300+. with supporting mods, 400 is easliy possible.
I think 300ish is all the tranny will reliably handle, but add cooling. You also will need oil cooling, and I think you need a three row radiator core installed. I only overheated my 2.6T once on a three row. I was climibing Bear Mountain Pass going to Lake Burton south shore on a 90* day. It's a steep pull on a long ago maintained FS road, and with all the turbo low end torque I could lug it up the grade creeping across the washboard at about 4ish mph without downshift, with very low air flow thru the radiator and very low water pump volume due to low rpm. The temp creeped up slowly, and when I downshifted into lo range, the problem went away. The tranny makes a tremendous amount of heat at low rpms since the stall is at 24-2600 rpm, and you need sub 200* water in the bottom tank water/oil cooler to suck it up, especially when the hot ambient makes the secondary air/oil cooler less effective. The tranny is durable, but you could heat a house with it.
Re: Found a dyno run with turbo swb oh yeah [Re: JAVYPRO] #1071723 05/30/14 04:24 PM
87monty Offline OP
Javy
Right on do you have access to some video of it???
That would be bad ass to see for sure. <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 SR
Re: Found a dyno run with turbo swb oh yeah [Re: fasteddy] #1071724 05/30/14 04:31 PM
87monty Offline OP
Thanks Eddy, as always you have great information,
I think 300Hp will be easy to obtain. The turbo im running should have gobs of low end for sure. Im going with my adapted jeep 5 speed with awd so this should be a hoot to drive.
I did the cooling upgrade a few years back. I installed a aluminum radiator from Jeggs and a aftermarket trans cooler. I pull a fully loaded camp trailer up steep grades with no over heating issues at all.
Radiator install link
96 SR
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6320 MB (Peak: 0.7361 MB) Data Comp: Off Server Time: 2026-07-14 10:50:22 UTC
