its seems my suspension is in worse shape then thought #1071870 05/24/14 02:38 AM
1
1morebike Offline OP
while heading out mountain biking the other day i hits pretty rough washboard and pot holes and realized my suspension is in worse shape then i thought. as we speak i have a 4 kyb shocks sitting in the garage and am a pay check or two from ordering a set one springs. i think this will help and plan to do they ball joints and tie rods as well. i would really like to replace all the bushings but cants find a kit. i know i can get the the ones for the control arms from rock auto but finding the rest seems to be a challenge, any help would be awesome.
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: its seems my suspension is in worse shape then thought [Re: 1morebike] #1071871 05/25/14 01:55 AM
plh Offline
I went for the whole UCAs in both my '92 and '93
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: its seems my suspension is in worse shape then thought [Re: 1morebike] #1071872 05/25/14 05:05 AM
Oso Offline
I searched for awhile and never found a kit. You can probably build your own kit out of poly bushings. i think most parts stores have a decent selection. I went with oem rubber. the stealer made up a kit and "bulk" price. don't remember what i paid, but i was pretty happy about it.
Re: its seems my suspension is in worse shape then thought [Re: plh] #1071873 05/25/14 05:46 AM
1
been thinking about that myself
Re: its seems my suspension is in worse shape then thought [Re: 1morebike] #1071874 05/25/14 07:07 AM
Oso Offline
Gen 2 UCA's mean you can bolt in a new ball joint when the time comes.
Re: its seems my suspension is in worse shape then thought [Re: Oso] #1071875 05/25/14 06:49 PM
1
so will they bolt right in? what about the lowers?
Re: its seems my suspension is in worse shape then thought [Re: 1morebike] #1071876 05/25/14 06:55 PM
Uppers should just bolt right in, although I've never done it. Don't think the lowers do.
As to the lowers, there's one bushing in the arm and it's "relatively" easy to change out. The other one (the rear bushing, lower arm) is mounted in the frame. It's not easy to change out and may not even need it, so inspect carefully before committing to tackle it.
Re: its seems my suspension is in worse shape then thought [Re: JohnnyBfromPeoria] #1071877 05/25/14 11:16 PM
Oso Offline
IIRC the lowers will take a different shock - just something else to consider. I think Justice swapped to Gen 2 lowers on his rig - maybe try searching him for more info.
Another thing you'll need with the UCA's are longer bolts. And there is a correct orientation for the the UCA as well. I think the thinner side faces inward, but I could be wrong. Be sure you find this info before you go for the new alignment.
Re: its seems my suspension is in worse shape then thought [Re: Oso] #1071878 05/26/14 03:23 AM
1
so do i just buy some uca for lets say 1992? once they are replaced to top ball joint will be bolt in while the lower will be press in? is there any other rear advantage to going with gen 2 ones
Re: its seems my suspension is in worse shape then thought [Re: plh] #1071879 05/26/14 04:50 AM
lordtrunks Offline
I have gen 2 uppers lowers spindles and torsion bars in my 89 all bolt on
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6346 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-06-07 07:27:30 UTC
