Getting rid of Old Blue and... #1072111 05/31/14 06:38 PM
jwp Offline OP
quick questions: upgrading from my 1991 to a 1995. I am looking at a low mileage (124k) vehicle.
It's an automatic....so that makes it a 3.5L with ABS and driver-side airbag correct?
1991 LWB Montero LS 213kmi - original. Stock.
2003 LWB Montero LTD 95kmi - original. All leather, stock and sweet
----Drive it like you have to use it to get to work in the morning.----
Re: Getting rid of Old Blue and... [Re: jwp] #1072112 05/31/14 10:31 PM
ryany Offline
In 95, the SR models had the 3.5 DOHC, the LS models came with the 3.0 - both were available with automatics. I think ABS and driver's airbag were standard in both models in 95.
95 Montero SR
Re: Getting rid of Old Blue and... [Re: ryany] #1072113 06/01/14 05:50 AM
Yes. 95 and 96sr's had 3.5 and ds airbag. Also had body lift, a/t, and selectrac. Good trucks. Check for play in the shaft that switches the butterflies between the low speed and high speed intake runners for any slop. The bushings wear out, the butterflies start to flutter, and the screws fail and the butterflies tour the combustion chamber and all the valves get dinged. Outside of leaking cam seals, that's about all that is iffy on that model. Other stuff breaks, but not commonly. Should have air locker (make sure the air compressor runs and stops, and doesn't cycle on often when you hit the R/D lock switch, or it has an expensive leak, perhaps unrepairable, as the locker doohicky in the diff is NLA).
It has adjustable shocks, three position switch on the console, expensive to replace, but seem to wear well.
LS 3.0 is a slug compated to the 3.5...
Re: Getting rid of Old Blue and... [Re: fasteddy] #1072114 06/01/14 05:35 PM
To go with what fasteddy said, you are looking at a low-mileage,, but 20-year old vehicle. Even though the three position shocks "wear well" as fasteddy stated, I have seen where low-mileage older vehicle start having issues that compound when it starts getting driven more as a daily driver. Look at that, you're looking at a truck that has averaged 6,000 miles a year. Not saying to be afraid, more like be prepared.
Re: Getting rid of Old Blue and... [Re: fasteddy] #1072115 06/02/14 11:29 PM
jwp Offline OP
Thanks guys, that is exactly what i needed. One more question: is Super Select gearbox the same as Select-trac? I am unfamiliar with this but I looked it up and it sounds cool.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6088 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-05-29 22:28:24 UTC
