Turn signal help on 89 Raider #1072301 06/11/14 06:40 PM
krenzy Offline OP
I have an 89 Raider SWB with a 3.0, and the turn signals don't work. They did for a short period of time two days ago when I bought it, but now nothing. The hazards work, although sometimes they start off as just one side then both. I verified the fuse is working and replaced the EL12 relay under the dash. I hear there are two of them; what is the other one? I just see one.
Any tips? I'd prefer to avoid replacing the turn signal switch itself unless that's the issue.
1989 Dodge Raider SWB, 3.0 V6, Automatic.
Re: Turn signal help on 89 Raider [Re: krenzy] #1072302 06/11/14 09:33 PM
Jay Ayala Offline
Its the turn signal relay above the left foot well.
Edit: turn signal flasher as opposed to turn signal relay
Re: Turn signal help on 89 Raider [Re: Jay Ayala] #1072303 06/11/14 10:26 PM
krenzy Offline OP
Can you give me a part number? That's where the LF12 (NAPA number) was and it didn't help. Just want to make sure I get the right one right away. Thank you so much!
Re: Turn signal help on 89 Raider [Re: krenzy] #1072304 06/11/14 10:53 PM
Jay Ayala Offline
Part number huh? Mmm... I wonder where I would get that. When I replaced my turn signal flasher, all I did was google three prong turn signal flasher for LED lighting and it that was that.
Re: Turn signal help on 89 Raider [Re: Jay Ayala] #1072305 06/11/14 11:04 PM
krenzy Offline OP
Forgive me, I'm not trying to be ignorant, I work at NAPA and our list shows a two prong and three prong, but under the drivers side dash I only see a two prong. I cannot find the three prong or the harness for it. I would imagine someone has a picture in case I'm missing something?
Re: Turn signal help on 89 Raider [Re: Jay Ayala] #1072306 06/11/14 11:16 PM
justice Offline
Not trying to state the obvious, but check to make sure the bulbs are not blown, or wrong amperage. The signal wont click in the dash, or trigger relay to flash if the bulb's in the tail lights amperage draw is too low. Also I believe too high resistance in wiring harness to the signals can cause this as well.
Had this intermittent issue with my 89, but when plugged into a trailer the turn signals were strong and fast. Try slightly higher wattage bulb maybe.
Re: Turn signal help on 89 Raider [Re: justice] #1072307 06/11/14 11:23 PM
krenzy Offline OP
Thank you for the tip. I'll check them out, and if they're good I'll read on how to post pictures and show you what I see under the dash.
Re: Turn signal help on 89 Raider [Re: krenzy] #1072308 06/12/14 01:47 AM
krenzy Offline OP
I've replaced all the bulbs as the 1157's showed some signs of corrosion and burns near the bottom inside. Nothing changed, it still won't work. All the hazards do, but not the turns. Here is a shot of the underside of my dash. Please tell me if something doesn't look right.
Re: Turn signal help on 89 Raider [Re: krenzy] #1072309 06/12/14 03:25 PM
Probably corrosion on terminals inside the hazard switch. If you remove and unplug it, you will see how to gently pry on the side catches and take it apart. Careful, springs and steel balls inside. Clean the contact surfaces with a rubber eraser and use contact grease. All the turn sig wiring goes thru the switch. Known failure point.
Justice, use a "heavy duty" flasher when trailering to get the light flash interval right. The heavier load of thee trailer lights makes the stock flasher work too fast...
Re: Turn signal help on 89 Raider [Re: fasteddy] #1072310 06/12/14 03:42 PM
krenzy Offline OP
Thank you! I'll give that a shot once I'm off work. I appreciate the help!
Does everything in that picture look correct? There are two things unplugged but I see no plug for them.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6378 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-05-30 01:21:28 UTC
