Curious bout what this does to my clutch... #1072320 06/11/14 09:39 PM
hacker Offline OP
Had an incident recently where I left the lights on to my '96 XJ 4.0 and killed the battery. During the jump it wouldn't start unless I gave it some gas and wouldn't stay running less I gave it gas as well. Computer eventually relearned idle after a couple times driving but to keep it running at stop signs I continued to give it gas at the same time as braking...which got me wondering. When you power brake a 4.0 what does that do to the clutch. If you can rev the motor without the wheels turning wouldn't this wear down the clutch? I'm just generally a little undereducated on how the clutch comes into play other than when shifting gears.
Thanks
~~_/) ~~
www.maps.org
Re: Curious bout what this does to my clutch... [Re: hacker] #1072321 06/12/14 01:31 AM
Mike Bondi Offline
If you were able to rev the engine, without putting down the clutch pedal, and the wheels weren't turning, then you already need a clutch. If you were reving the engine with the clutch pedal depressed, then you weren't damaging the clutch, unless you were slipping it. When the clutch pedal is depressed, then the throwout bearing is spinning, and your trans is disengaged....be cool....Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
Re: Curious bout what this does to my clutch... [Re: hacker] #1072322 06/13/14 08:59 AM
4x4Wire Offline
Expanding on what Mike said, the clutch is the leverage that temporily disconnects the engine from the transmission. The "throw-out bearing" is one of four critical components. When you depress the clutch pedal, a fork engages the throw out bearing and separates the clutch face from the flywheel allowing you to shift gears without grinding gears.
If you slip the clutch, you are not completely separating the clutch plate from flywheel contact. Do it often and long and you create a lot of heat from the slight friction between flywheel and clutch. You will burn the clutch, ie, polish it smooth, along with damaging the flywheel surface.
If you were engaging the clutch and shifting to neutral, you can safely let out the clutch. Slowing without shifting to neutral while reving the engine with foot on brake, will cause more problems with brakes than clutch.
You will know about problems before they become serious as the throw out bearing will make noise and you will have trouble shifting. Slipping the clutch causes heat buildup and burning of the clutch. You will smell it much like you can smell overheated brakes.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5954 MB (Peak: 0.6490 MB) Data Comp: Off Server Time: 2026-05-29 15:38:17 UTC
