MONTERO 1990 ENGINE SWAP ADVICE NEEDED #1072403 06/13/14 05:42 PM
BigNate66 Offline OP
I OWN MY 1ST MONTERO 4X4 ! YAHOOOOOO!!!
HEY I NEED TO CHANGE THE ENGINE, GOT BAD KNOCK & METAL SOUNDS.
STOCK 3.0 LTR V6 HAS FAILED AT 290,000 MILES.
WHAT ARE MY OPTIONS HERE?
I HEAR STUFF ABOUT TURBO'S THAT BOLT RIGHT IN LIKE FROM
A CONQUEST OR STARION?
I'M LOOKING FOR SOMETHING MORE GO THAN STOCK 3.0
THANK YOU ALL FOR HELP AND FOR READING.
1990 MITSUBISHI MONTERO LS
4X4 AUTO 3.0 LTR V6
290,000 MILES
Re: MONTERO 1990 ENGINE SWAP ADVICE NEEDED [Re: BigNate66] #1072404 06/13/14 11:13 PM
Sorry, the turbo motor swap is only for the 2.6 trucks, unless you want to go really wild and use a Stealth 3.0 dohc twin turbo, and it's somewhat of a pain to pull off. I don't believe I've seen one native to this forum, but have seen some unconfirmed posts elsewhere. About the only way to get more power cheap on the sohc 3.0 is to use Diamante (?) pistons with higher compression. I'm not an expert on that.
Please turn off the capslock, and welcome aboard. We can tell you how to rebuild the motor right, if the block is salvagable, and what donor blocks you can use. Plan on rodding out the radiator for sure, and go to pulling the motor and seeing how bad it is...
Re: MONTERO 1990 ENGINE SWAP ADVICE NEEDED [Re: BigNate66] #1072405 06/14/14 04:15 AM
Bernoulli Offline
Here's an Australian forum thread with opinions and guesses over improvements on the 6G72:
http://www2.pajeroclub.com.au/forum/showthread.php?t=6639
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: MONTERO 1990 ENGINE SWAP ADVICE NEEDED [Re: Bernoulli] #1072406 06/16/14 03:04 AM
Depends on how talented you are, 3.5 swaps are awesome and much more power than turbo 2.6, for this you will need a good donor truck and you will wire everything yourself.
I've heard about aussies swapping the 3.5 block under 12v 3.0 heads/EFI and tuned to work but i know nothing about that.
Re: MONTERO 1990 ENGINE SWAP ADVICE NEEDED [Re: BigNate66] #1072407 06/25/14 03:44 PM
BottomFeeder Offline
There are a few who have done the Chevy 4.3 swap and I believe a ford 302 swap somewhere around here.
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: MONTERO 1990 ENGINE SWAP ADVICE NEEDED [Re: BottomFeeder] #1072408 06/25/14 03:57 PM
Malykaii Offline
Isn't the 4.3 swap also best done in a 2.6? I know the 2.6 and 3.0 trucks' frame rails up front are different widths apart.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6815 MB) Data Comp: Off Server Time: 2026-06-07 04:50:16 UTC
