Re: Gen II has a smoking habit [Re: jdavis] #1072569 07/24/14 06:30 PM
JoeBurt Offline
My 94 SR does the same thing. I need to do the lash adjusters and seals too. I just did the timing belt and intake manifold gaskets, I don't really want to take all apart again. Let me know what you find out about on the timing belt.
Re: Gen II has a smoking habit [Re: JoeBurt] #1072570 07/24/14 07:43 PM
jdavis Offline OP
Yep, I just replaced timing belt, h2o pump, etc..... as well.
I really don't want to take TB off either. What a PITA to get back on. Pretty positive it has to come off, since the cam shafts have to be removed to gain access to springs and seals. Unless some one out there has a trick up their sleeve?
If you want to tag team the job, I have room for two Montero's in the shop <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Gen II has a smoking habit [Re: jdavis] #1072571 07/24/14 08:12 PM
Djunk Offline
[quote]Spring Compressor -
I asked this same question a whi.../catalog/item.asp?...e=&tool=all
as you'll see it reasonably priced and this video
http://www.youtube.com/watch?v=aP9GJuHO7N8&feature=related
demonstrates very nicely the whole procedure but on a 6G72 engine.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: Gen II has a smoking habit [Re: Djunk] #1072572 07/24/14 08:34 PM
Djunk Offline
Sorry about the quotes above, I don't know what happened. I believe that A member on here verified that the DNJ were the vitton type and are supposed to be the best. Also I'm pretty sure that to do the seals you will have to remove the cam shafts to get to the seals and the timing belt will have to come off.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6076 MB (Peak: 0.6814 MB) Data Comp: Off Server Time: 2026-07-15 02:37:35 UTC
