Page 2 of 3 1 2 3
Re: Options when you can't find a new relay? [Re: krenzy] #1072597 06/26/14 04:38 AM
I think there are two water temp switches. The one for the a/t is open at room temp, and the one for the a/c is closed at room temp.
Re: Options when you can't find a new relay? [Re: fasteddy] #1072598 06/26/14 04:47 AM
krenzy Offline OP
Of the two switches I posted, the newer one is slightly thinner than the older one, so it will not fit in the hole. Which is fine since it's not the correct switch for that spot, but what is? I can't find a part number that works. The dealership came up with a F fitting vacuum line, which is obviously wrong.
1989 Dodge Raider SWB, 3.0 V6, Automatic.
Re: Options when you can't find a new relay? [Re: krenzy] #1072599 06/26/14 07:51 AM
mxmikie Offline
autozone has it listed as TU317 temp sensor
Re: Options when you can't find a new relay? [Re: mxmikie] #1072600 06/26/14 07:57 AM
mxmikie Offline
you could also use temp sensor Standard TS-333
Re: Options when you can't find a new relay? [Re: mxmikie] #1072601 06/26/14 08:09 AM
mxmikie Offline
Re: Options when you can't find a new relay? [Re: krenzy] #1072602 06/26/14 05:48 PM
I
ironick Offline
I replace mine with a 12 volt cube relay, was able to take the wires from the plug. I works just fine for cheap. Just ring out the wires with a meter.
Re: Options when you can't find a new relay? [Re: mxmikie] #1072603 06/26/14 06:25 PM
krenzy Offline OP
Mxmikie thank you so much! I've had everyone in town looking for it; I guess the devil is in the name of the part. I've seen so many different names, but I ordered one so thank you!
Re: Options when you can't find a new relay? [Re: krenzy] #1072604 06/27/14 01:36 AM
mxmikie Offline
if you need the relay after all this i have coffee cans full of them
Re: Options when you can't find a new relay? [Re: mxmikie] #1072605 06/27/14 11:07 PM
krenzy Offline OP
Well mxmikie, if you could PM me with what you'd want for one, I'd appreciate it. The new switch did not change anything.
Re: Options when you can't find a new relay? [Re: krenzy] #1072606 06/28/14 06:24 AM
mxmikie Offline
pm sent
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6373 MB (Peak: 0.7446 MB) Data Comp: Off Server Time: 2026-07-09 16:14:32 UTC
